I'm trying to build finalhe and exfat-nofuse. It's my first time trying something of that sort. I'm using lUbuntu 18.04. I tried following info found on the finalhe GitHub page and these links: https://github.com/soarqin/finalhe/
How to install exfat-nofuse?
https://www.reddit.com/r/vitahacks/comments/5nkgcu/theflow_finally_release_vitashell_update_with_usb/dccekoh/?context=3 (I can't seem to quote the specific comment appropriately, but it is the second one you see)
I get the following errors when trying to build finalhe with CMake and exfat-nofuse, respectively:
>>>>FOR FINALHE:<<<<
cmake ~/Downloads/finalhe-1.5
CMake Error at CMakeLists.txt:36 (find_package):
  By not providing "FindIconv.cmake" in CMAKE_MODULE_PATH this project has
  asked CMake to find a package configuration file provided by "Iconv", but
  CMake did not find one.
  Could not find a package configuration file provided by "Iconv" with any of
  the following names:
    IconvConfig.cmake
    iconv-config.cmake
  Add the installation prefix of "Iconv" to CMAKE_PREFIX_PATH or set
  "Iconv_DIR" to a directory containing one of the above files.  If "Iconv"
  provides a separate development package or SDK, be sure it has been
  installed.
-- Configuring incomplete, errors occurred!
See also "/home/myusername/Downloads/finalhe-1.5/CMakeFiles/CMakeOutput.log".
>>>>AS FOR EXFAT-NOFUSE I GET THE FOLLOWING:<<<<
sudo make install
rm -f /lib/modules/4.15.0-33-generic/kernel/fs/exfat/exfat.ko
install -m644 -b -D exfat.ko /lib/modules/4.15.0-33-generic/kernel/fs/exfat/exfat.ko
depmod -aq
depmod: WARNING: Ignored deprecated option -q
sudo modprobe exfat_fs
modprobe: FATAL: Module exfat_fs not found in directory /lib/modules/4.15.0-33-generic
I copied CMakeOutput.log onto https://hastebin.com/ejaralegub.sql
I thank you for your patience and comprehension in advance!
N0rbert
  • 103,263
It looks like you don't have iconv installed. If that's the case, you can install it by installing libc6 or libc6-dev. Once installed, try building the package again.
Let's make it reproducible on clean 18.04 LTS.
1. FinalHE
To build finalhe we need to install the following.
sudo apt-get install git cmake build-essential libxml2-dev libusb-dev \
zlib1g-dev qtbase5-dev qttools5-dev libusb-1.0-0-dev qt5-qmake qt5-default
Then download source code (master branch, not v1.5 release!):
cd ~/Downloads
git clone https://github.com/soarqin/finalhe.git
cd finalhe
And build it with qmake:
qmake
make
sudo make install
And test it:
~/Downloads/finalhe/src/FinalHE
FinalHE
2. exFAT-noFUSE
Download and compile it:
cd ~/Downloads
git clone https://github.com/rxrz/exfat-nofuse.git
cd exfat-nofuse
make
sudo make install
Then load compiled module:
sudo modprobe exfat
Note: I have not used this software, just tried to compile it to help you.
N0rbert
  • 103,263
