My laptop have already installed Windows 10 in UEFI but I mistakenly dual boot Ubuntu OS In legacy mode. So everytime I have to change BIOS SETUP settings to UEFI for Windows and legacy and legacy first for Ubuntu. So what I do to when I start my pc it ask me which OS to use(it also ask currently but don't run the other one according to BIOS setting)
The switch from legacy boot to UEFI boot in Ubuntu should be fairly easy, only a few steps are needed.
First of all make sure that Windows is fully shut down, Windows Fast-startup-feature should be disabled. Boot your current Ubuntu installation.
You need to know which partition is your EFI-System-Partition (ESP). You can use the command lsblk -f to get the device name and UUID of the ESP. The ESP is formatted in FAT and normally has a size of a few hundred MB, mostly the partition will be labeled and you can find it easily.
Create a directory as mount-point for the ESP with
sudo mkdir /boot/efi
Now add a line to /etc/fstab with the following content:
UUID=XXXXXXXXX /boot/efi vfat umask=0077 0 1
Use the UUID you found before.
Mount the ESP with sudo mount-a
Now install the grub-efi-amd64-package:
sudo apt install grub-efi-amd64
This will automatically remove grub-pc (the legacy boot-mode version of Grub).
Other commands like grub-install or update-grub are not needed, installing grub-efi-amd64 will install the boot-loader to the ESP during installation of the package.You are ready to reboot.
Enter the UEFI-settings and check your boot-order. I'd also recommend to disable CSM in UEFI-settings to speed up the boot process.
- 18,644
I suggest you to reinstall Ubuntu in UEFI mode cause moving from legacy to UEFI not so simple. You should:
- Boot from Live-USB;
- Create FAT32 partition (minimum 33MB of size) and mark it with boot flag;
- Enter chroot mode by:
sudo mount -o /dev/sdxX /mntwhere xX is you drive and partition number where a root partition is;sudo mount /dev/sdxX /mnt/boot/efifor i in /dev /dev/pts /proc /run /sys; do sudo mount -B $i /mnt$i; donesudo chroot /mntfor i in /dev /dev/pts /proc /run /sys; do sudo mount -B $i /mnt$i; donesudo chroot /mnt
Now install grub:
apt-get install --reinstall grub-efi-amd64
grub-install --recheck /dev/sdX
or just:
dpkg-reconfigure grub-efi-amd64
It should create 'ubuntu' menu item in UEFI.
Now edit your fstab by sudo nano /etc/fstab and add the following to it:
UUID=bla-bla /boot/efi vfat umask=0077 0 1
You should run blkid to identify which UUID your efi partition has.
Check which packages are installed by dpkg --get-selections | grep grub
grub-common install
grub-efi install
grub-efi-amd64 install
grub-efi-amd64-bin install
grub2-common install
Those are packages should be installed for UEFI boot. All other you should remove.
Also check that /EFI/ubuntu/grubx64.efi file is exist.
Exit from chroot by Ctrl+D.
Unmount all in /mnt and try to reboot.
- 521
- 2
- 9
