VLC 2.0.1 is behaving oddly, and since it does not appear to offer any increase in performance over 1.1.12 I would like to downgrade to the latter. However, this appears to be non-trivial.
After running these commands:
sudo apt-get remove --purge vlc
sudo add-apt-repository -r ppa:videolan/stable-daily
sudo apt-get update
VLC 2.0.1 should be gone, as should the ppa from which I got it. However, it is still not possible to install VLC 1.1.12. When I try to, I get an error message about broken dependencies:
Reading package lists... Done
Building dependency tree
 vlc : Depends: vlc-nox (= 1.1.12-2~oneiric1) but 2.0.0+git20120222+r100-0~r29~oneiric1 is to be installed
       Depends: libvlccore4 (>= 1.1.0) but it is not going to be installed
       Recommends: vlc-plugin-notify (= 1.1.12-2~oneiric1) but it is not going to be installed
       Recommends: vlc-plugin-pulse (= 1.1.12-2~oneiric1) but it is not going to be installed
How can I reinstall VLC 1.1.12?
bessman
  • 7,585
Re-add the ppa that you downloaded 2.0.1 from, and then use ppa-purge. More info can be found here:
Chris Wayne
  • 3,292
