When I power on my laptop, I see the boot menu. However, when I select Windows 10, it doesn't start, it shows only a black screen.
My Ubuntu 18.04 is booting fine.
How can I restore the possibility to boot into Windows 10?
Zanna
  • 72,312
Your Windows bootloader may have been corrupted. You can solve the issue with the steps below.
  1. Insert a bootable USB/DVD of Windows
  2. Boot using that bootable USB/DVD
  3. Select the "Repair my computer" option that you will get after clicking the install button.
  4. If that does not work (error message "Windows failed to repair", then open a command prompt using 'advanced options' and run the following 3 commands
    bootrec /fixmbr
    bootrec /fixboot
    bootrec /rebuildBCD
  5. Restart your computer and check whether it works or not.
vanadium
  • 97,564
