In order to install Xtreme Download manager, I've used the following commands based on what is said here.
sudo add-apt-repository ppa:noobslab/apps
sudo apt-get update
sudo apt-get install xdman
But here's what I get from the terminal and I can't get it installed:
sepideh@sepideh-Lenovo-ideapad-700-15ISK:~$ sudo add-apt-repository ppa:noobslab/apps
[sudo] password for sepideh:
 This PPA Contains Applications for Ubuntu/Linux Mint from different sources but debianized by http://www.NoobsLab.com
 More info: https://launchpad.net/~noobslab/+archive/ubuntu/apps
Press [ENTER] to continue or Ctrl-c to cancel adding it.
Ign:1 http://dl.google.com/linux/chrome/deb stable InRelease Get:2 http://security.ubuntu.com/ubuntu bionic-security InRelease [83.2 kB] Ign:3 http://ppa.launchpad.net/noobslab/apps/ubuntu bionic InRelease Hit:4 http://us.archive.ubuntu.com/ubuntu bionic InRelease Hit:5 http://dl.google.com/linux/chrome/deb stable Release Get:7 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB] Err:8 http://ppa.launchpad.net/noobslab/apps/ubuntu bionic Release 404 Not Found [IP: 91.189.95.83 80] Get:9 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB] Hit:10 https://repo.windscribe.com/ubuntu zesty InRelease Reading package lists... Done E: The repository 'http://ppa.launchpad.net/noobslab/apps/ubuntu bionic Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. sepideh@sepideh-Lenovo-ideapad-700-15ISK:~$ sudo apt-get update Ign:1 http://dl.google.com/linux/chrome/deb stable InRelease Hit:2 http://dl.google.com/linux/chrome/deb stable Release Get:4 http://security.ubuntu.com/ubuntu bionic-security InRelease [83.2 kB] Hit:5 http://us.archive.ubuntu.com/ubuntu bionic InRelease Ign:6 http://ppa.launchpad.net/noobslab/apps/ubuntu bionic InRelease Get:7 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB] Err:8 http://ppa.launchpad.net/noobslab/apps/ubuntu bionic Release 404 Not Found [IP: 91.189.95.83 80] Get:9 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB] Hit:10 https://repo.windscribe.com/ubuntu zesty InRelease Reading package lists... Done E: The repository 'http://ppa.launchpad.net/noobslab/apps/ubuntu bionic Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. sepideh@sepideh-Lenovo-ideapad-700-15ISK:~$ sudo apt-get install xdman Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package xdman sepideh@sepideh-Lenovo-ideapad-700-15ISK:~$
What should I do?
NotTheDr01ds
  • 22,082
Noobslab PPA no longer appears to maintain an XDMan release for current Ubuntu releases. The last update was for Xenial Xerus. As far as I know, XDMan does not have any reliable PPA at the moment. Instead ...
Install using Tarball
  1. OpenJDK should have been installed already. Check via Terminal: java --version. If you get Command 'java' not found install it with:
    sudo apt-get update
    sudo apt-get install openjdk-11-jre
    and hit Enter if asked.
  2. Download the lastest XDMan release here (currently 7.2.11 at the time of this edit).
    Note that recent releases are 64-bit only. If you need a 32-bit release, the latest is 7.2.7.
  3. After finishing the download open Terminal and cd to the download directory; for example: cd ~/Downloads/Programs
  4. Run tar -xvf xdm-setup-7.2.11.tar.xz (for latest release) or tar -xvf xdm-2018-x86.tar.xz (for the 32-bit release).
    NOTE: You may not want to extract the file using FileRoller or other software, as it may not extract it appropriately.
  5. Run sudo ./install.sh
Xtreme Download Manager is now installed on your system.
NotTheDr01ds
  • 22,082
Find the latest version (currently 7.2.11) on the XDM Downloads Page or the Github releases page. Adjust the filenames as needed below to download, extract, and run install.sh:
wget https://github.com/subhra74/xdm/releases/download/7.2.11/xdm-setup-7.2.11.tar.xz
sudo sh install.sh
NotTheDr01ds
  • 22,082
Prox
  • 81
