Grep with -r was not working for me.
I then made a test situation. The directory /home/den/backup now contains a file with the word washer in it. I also made a subdirectory within /home/den/backup. In that directory a file contains the word washer. The following should return two hits at /home/den/backup/great.txt and /home/den/backup/aaa/info.txt
If I issue
grep -r "washer" /home/den/backup/*.*
the result is one hit.
If I issue
grep -r "washer" /home/den/backup/aaa/*.*
Shouldn't the first one have also found the second one, which is in one if its sub-directories?
