15
When I want to upgrade Ubuntu from 18.04 Bionic Beaver to 18.10 to Cosmic Cuttlefish via terminal with sudo do-release-upgrade -d command it gives me warning:
Failed to connect to https://changelogs.ubuntu.com/meta-release-development.
Check your Internet connection or proxy settings.
However I have internet connection, I write this question now from my Ubuntu computer.
How can I resolve this?
Zanna
  • 72,312
ayibugan
  • 151
It seems like there is an issue about certificates:
result of meta-release download: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:841)>
As a workaround, I edited the file /usr/lib/python3/dist-packages/UpdateManager/Core/MetaRelease.py and added these lines to the beginning:
import ssl
ssl._create_default_https_context = ssl._create_unverified_context
14
The problem is the used ca:
$ python3 -c 'import ssl; print(ssl.get_default_verify_paths().openssl_cafile)'
/usr/lib/ssl/cert.pem
The path might be /usr/local/ssl/cert.pem for your installation, adjust following commands to use this path if it's your case.
But:
$ ls /usr/lib/ssl/cert.pem
ls: cannot access '/usr/lib/ssl/cert.pem': No such file or directory
You can fix it by linking the global ca-certificates to the file Python uses:
ln -s /etc/ssl/certs/ca-certificates.crt /usr/lib/ssl/cert.pem
After that running do-release-upgrade works just fine.
For a temporary solution:
SSL_CERT_FILE=/etc/ssl/certs/ca-certificates.crt do-release-upgrade
This is an Ubuntu bug that has been fixed, but I'm not sure if the patch will be available in updates for 18.04.2 LTS.
From 2018:
update-manager (1:18.10.3) cosmic; urgency=medium
  • Add support for HTTPS proxies; this breaks UpdateManager.Core.utils.init_proxy() API - the return value is now a dict, rather than a string (LP: #1771914).
    The verification of the Stable Release Update for update-manager has completed successfully and the package has now been released to -updates.
TonyG
  • 187
