19
I only recently discovered the different JVM's on the wiki page and thought I'd start tinkering. Its been difficult to find documentation on how to configure Java on Ubuntu though.
Lets say I wanted to change the JRE or JDK that I'm using, I could crack open a terminal and say
sudo update-alternatives --config java
And then pick from one of the installed versions.
If I'm understanding JVM's right (which I may very well be not), You can configure the openJDK to use alternative JVM's (Eg JAMVM) and run it as such
jamvm -jar foo.jar
2 questions,
1: Do i have the concept of a JVM right? As in, is this possible?
2: If so how do i configure the JVM and switch the default to a JVM of my choosing?
OVERTONE
  • 2,407
Feel free to use this as a reference to tinkering with Java at runtime.
Choosing your JRE
To choose your JRE, use
This will give something like the following output.
  Selection    Path                                            Priority   Status
  0            /usr/lib/jvm/java-6-openjdk/jre/bin/java         1061      auto mode
* 1            /usr/lib/jvm/java-6-openjdk/jre/bin/java         1061      manual mode
  2            /usr/lib/jvm/java-6-sun/jre/bin/java             63        manual mode
  3            /usr/lib/jvm/java-7-openjdk-amd64/jre/bin/java   1051      manual mode
You can then select which Java runtime you want through the number selection.
Choosing your JVM
Sun/Oracle have two JVM choices, -server and -client. If you select the OpenJDK as your Java runtime environment you have additional options.
When you type java into the terminal with no other parameters, the help lists several optional VMs. I'm not sure which ones come with OpenJDK but 3 popular ones are JamVM, Zero and Cacao
To use these, simply type
java -jamvm 'your other parameters here'
java -cacao 'your other parameters here'
java -zero 'your other parameters here'
java -server 'your other parameters here
The -server VM is normally the default. You can also specify -client but in 64-bit IcedTea6 it appears to run the same version as -server. There are most likely others but I find the default option to be the most responsive.
Setting your Memory
Finally, how to set the memory of Java (just because)
java -Xmx1024m -Xms128m 'your other parameters here'
This limits the memory allowed for the Java program to a maximum of 1024 MB, and sets its initial memory size to 128 MB. This is a great way of defining minimum system requirements. The Java 6 man page for the java command describes these options and others.
That's all. If anyone has additional Java tweaks for Ubuntu then leave them in the comments and I'll add them.
skierpage
  • 313
OVERTONE
  • 2,407
To set the default JVM inside an OpenJDK installation you need to edit the jvm.cfg configuration file located inside the /usr/lib/jvm/java-version-openjdk-arch/jre/lib/arch/jvm.cfg
Ubuntu expose the jvm.cfg file inside the /etc/ directory depending on OpenJDK version. /etc/java-6-openjdk/jvm-arch.cfg or /etc/java-7-openjdk/jvm-arch.cfg
The top most -jvmname KNOWN line inside the jvm.cfg file determine the default JVM.
There is no configuration tool available thus you have to locate and edit these files manually.
xranby
  • 990
