I recently moved from windows to lubuntu 18.04 and i've installed wine 3.14 following this guide (https://linuxconfig.org/install-wine-on-ubuntu-18-04-bionic-beaver-linux). How can i update wine to 3.15 without losing all the data of the application that i'm using (for example games saves)? Thanks in advance.
Wine data is stored within the WINEPREFIX directory, usually at /home/$USER/.wine/ unless otherwise defined. Such directories are not deleted during the upgrade process. (You'd have to physically delete the directory yourself)
You don't need to worry about that data being 'lost' when you update Wine versions.
However, if you really are concerned about that, make a copy of your Wine prefix elsewhere called "wine_backup" or similar with cp -r ~/.wine ~/.winebackup first - this way you can always restore the data if the .wine directory goes away by doing rm -rf ~/.wine && cp -r ~/.winebackup ~/.wine (which will remove a 'bad' wineprefix if it exists and restore the backup.
You may wish to read up on the WineHQ guide for Ubuntu on how to deploy newer Wine (latest stable) on your system. They maintain a repository now for Ubuntu versions of the latest Wine. (I'm on my phone, I can't copy in the data from that site now, but I will at my earliest convenience after work this evening - assuming I remember)
Thomas Ward
  • 78,878
Usually data/programs installed via wine are kept in your home directory (under ~/.wine), so they won't be affected by an upgrade.
As a matter of fact I've upgraded wine on my systems for years without any (apparent) problem, both using official ubuntu packages and winehq provided repos.
As for how to upgrade wine, you'll find plenty of examples/tutorials on the net, many on this site, too.
