I installed Codeblocks 17.12-1 and it's not responding after building the file. So I wanna try Codeblocks 16.01 from the terminal but it shows errors.
:~$ sudo apt install codeblocks
[sudo] password for salil:
Reading package lists... Done
Building dependency tree
codeblocks : Depends: codeblocks-common (= 16.01+dfsg-2.1) but it is not
going to be installed
Remove the codeblocks-common.
sudo apt-get remove codeblocks-common
then
sudo apt install -f
sudo apt-get update.
Now try to reinstall. It should work now.
Kulfy
  • 18,154
