I'm trying to build this repo for neural networks implemented in CUDA.
I've followed the instructions in that link and performed the following actions on a shell:
git clone https://github.com/ANNetGPGPU/ANNetGPGPU.git
cd ANNetGPGPU
mkdir build
cd build
cmake .. && make
However, when I write that last line, the following error is returned:
CMake Error at /home/iibm/Documents/martins/cmake-3.12.1-Linux-x86_64/share/cmake-3.12/Modules/FindPackageHandleStandardArgs.cmake:137 (message):
  Could NOT find BZip2 (missing: BZIP2_LIBRARIES BZIP2_INCLUDE_DIR)
Call Stack (most recent call first):
  /home/iibm/Documents/martins/cmake-3.12.1-Linux-x86_64/share/cmake-3.12/Modules/FindPackageHandleStandardArgs.cmake:378 (_FPHSA_FAILURE_MESSAGE)
  /home/iibm/Documents/martins/cmake-3.12.1-Linux-x86_64/share/cmake-3.12/Modules/FindBZip2.cmake:62 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
  CMakeLists.txt:7 (FIND_PACKAGE)
-- Configuring incomplete, errors occurred!
See also "/home/iibm/Documents/martins/ANNetGPGPU/build/CMakeFiles/CMakeOutput.log".
But bzip2 is definitely installed, as bzip2 --version returns:
bzip2, a block-sorting file compressor.  Version 1.0.6, 6-Sept-2010.
   Copyright (C) 1996-2010 by Julian Seward.
So how can I fix this issue, and why is it happening?
Tendero
  • 133
When you build software that uses libraries such as bzip2, you need to have the -dev package installed, which includes the header files (*.h) needed by the compiler and the library files needed by the linker.
In your case, for bzip2, on Ubuntu, the name of the package with the files you need is libbz2-dev, so you can solve this problem by installing this package:
sudo apt-get install libbz2-dev
N0rbert
  • 103,263
filbranden
  • 2,861
