We have a Windows Dell Server with a corrupt RAID array. We ran Ubuntu from a USB stick and managed to copy some files from the C drive, but the D drive (DATA) we cant mount or access, I guess its to corrupt to do that, but are there any way to come around this problem , we are not precisely Ubuntu experts, we just are trying to save a couple of files that where locked in the previous back up. Any help is very appreciated!
Asked
Active
Viewed 4.3k times
Check the name of the partition:
sudo fdisk -l
If the name of the windows ntfs partition is for example sda3:
sudo mkdir /media/OS
sudo mount -t ntfs -o nls=utf8,umask=0222 /dev/sda3 /media/OS
An0n
- 2,225
For Ubuntu 18.10:
First install
cifs-utilsusing:sudo apt-get install cifs-utilsNow run following command:
sudo mount -t cifs //xxx.xxx.xxx.xxx/network-drive-folder /mnt -o username=testuser,vers=1.0Here, my source (to be mounted) is -
//xxx.xxx.xxx.xxx/network-drive-folderand destination (where it is to be mounted) is/mnt(system provided mounting point).
testuseris a username which has access to windows network drive. And last but very crucialvers=1.0. For someonevers=2.0orvers=3.0also work as per system stack.
BeastOfCaerbannog
- 16,703
Sohel Pathan
- 111
