A brief background:
Recently, I had deleted libnl-3-200 library by mistake.. and was able to fix the issue as described in Deleted libnl-3-200 by mistake
After the network was working, I did sudo apt-get autoremove and sudo apt-get autoclean. I noticed that ubuntu is trying to remove important packages, so I stopped the process by pressing Ctrl + C.
I have two desktops : fvwm and gnome(ubuntu-default). After I restarted my system, the gnome desktop did not show up in the login screen. Also, I use wicd network manager to connect to internet.
I tried to follow this link Broken packages error while installing zookeeper-server but didn't helped me.
When I do sudo apt-get install shutter, I get:
Reading package lists... Done
Building dependency tree
shutter : Depends: libgnome2-perl but it is not going to be installed
Depends: libgnome2-vfs-perl but it is not going to be installed
Depends: libgtk2-unique-perl but it is not going to be installed
Next, I tried to run sudo apt-get purge shutter.
Log is:
The following packages were automatically installed and are no longer required:
apturl apturl-common epiphany-browser-data gir1.2-gmenu-3.0
gnome-session-common guile-2.0-libs libatk1.0-0:i386
libavahi-common-data:i386 libavahi-common3:i386 libavahi-gobject0
libavahi-ui-gtk3-0 libbonobo2-0 libbonobo2-common libbonoboui2-common
libcairo2:i386 libclass-data-inheritable-perl libclass-method-modifiers-perl
libcommon-sense-perl libcrypt-openssl-bignum-perl libcrypt-openssl-rsa-perl
libdata-random-perl libdatrie1:i386 libedata-cal-1.2-28 libexiv2-14
libexpat1:i386 libffi6:i386 libfontconfig1:i386 libfreerdp-cache1.1
libfreerdp-client1.1 libfreerdp-codec1.1 libfreerdp-common1.1.0
libfreerdp-core1.1 libfreerdp-crypto1.1 libfreerdp-gdi1.1
libfreerdp-locale1.1 libfreerdp-plugins-standard libfreerdp-primitives1.1
libfreerdp-utils1.1 libfreetype6:i386 libgcrypt20:i386 libgd-perl
libgdk-pixbuf2.0-0:i386 libgexiv2-2 libglib2.0-0:i386 libgmp10:i386
libgnome2-canvas-perl libgnome2-gconf-perl libgnome2-wnck-perl
libgnomecanvas2-0 libgnomecanvas2-common libgnomeui-common libgnutls30:i386
libgoo-canvas-perl libgoocanvas-common libgoocanvas3 libgraphite2-3:i386
libgssapi-krb5-2:i386 libgtk2-appindicator-perl libgtk2-imageview-perl
libgtkimageview0 libharfbuzz0b:i386 libhogweed4:i386
libhttp-server-simple-perl libidn11:i386 libimage-magick-perl
libimage-magick-q16-perl libjbig0:i386 libjpeg-turbo8:i386 libjpeg8:i386
libjson-perl libjson-xs-perl libk5crypto3:i386 libkeyutils1:i386
libkrb5-3:i386 libkrb5support0:i386 libmouse-perl libnet-dropbox-api-perl
libnet-oauth-perl libnettle6:i386 liborbit-2-0 libp11-kit-gnome-keyring
libp11-kit0:i386 libpango-1.0-0:i386 libpangocairo-1.0-0:i386
libpangoft2-1.0-0:i386 libpath-class-perl libpixman-1-0:i386 libpng12-0:i386
libproc-processtable-perl libproc-simple-perl libraw15
libsort-naturally-perl libssh-4 libsystemd0:i386 libtasn1-6:i386
libthai0:i386 libtiff5:i386 libtypes-serialiser-perl libvncclient1
libwinpr-crt0.1 libwinpr-dsparse0.1 libwinpr-environment0.1 libwinpr-file0.1
libwinpr-handle0.1 libwinpr-heap0.1 libwinpr-input0.1
libwinpr-interlocked0.1 libwinpr-library0.1 libwinpr-path0.1
libwinpr-pool0.1 libwinpr-registry0.1 libwinpr-rpc0.1 libwinpr-sspi0.1
libwinpr-synch0.1 libwinpr-sysinfo0.1 libwinpr-thread0.1 libwinpr-utils0.1
libwnck-common libwnck22 libwww-mechanize-perl libxcb-render0:i386
libxcb-shm0:i386 libxcomposite1:i386 libxcursor1:i386 libxdamage1:i386
libxfixes3:i386 libxinerama1:i386 libxrandr2:i386
linux-signed-image-4.4.0-128-generic oneconf-common p11-kit p11-kit-modules
perlmagick planner-data planner-doc python-aptdaemon
python-aptdaemon.gtk3widgets python-attr python-blinker python-cups
python-debian python-debtagshw python-defer python-dirspec python-httplib2
python-jwt python-oauthlib python-oneconf python-pam
python-piston-mini-client python-pyasn1-modules python-serial
python-service-identity python-twisted-bin python-twisted-core
python-twisted-web python-xapian python-zope.interface python3-oneconf
python3-piston-mini-client remmina-common scrollkeeper shotwell-common
software-center-aptdaemon-plugins
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
shutter*
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 349811 files and directories currently installed.)
Removing shutter (0.93.1-1ubuntu1) ...
Purging configuration files for shutter (0.93.1-1ubuntu1) ...
Please help me to correct this issue?
