I am building a home server with raid 5. I first set up the system to boot from compact flash. After i got that working I tried to create the raid 5 array. All disks are new and have no data on them. I used the following command to create the array:
mdadm --create --verbose /dev/md0 --level=5 --raid-devices=3 /dev/sd[bcd]1
After this I ran 'watch cat /proc/mdstat'. The system is recovering - very very slowly (like 40 hours to recover).
How do I tell the system these are new disks with no user data on? I don't want to recover anything.
Amir
  • 591
Unfortunately that's just part of the joyous mdadm build process. At least that's been my experience of it... But I have only done it twice.
You can speed things up by increasing the stripe cache
sudo su
echo 8192 > /sys/block/md0/md/stripe_cache_size
You can run that now and it should have near-immediate effect.
That won't persist between restarts but if it does improve performance, you can make it.
Oli
  • 299,380
