In my Ubuntu 18.04 LTS:
marco@PC:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.1 LTS
Release:        18.04
Codename:       bionic
I have gcc version 7.3.0:
marco@PC:~$ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/7/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu
7.3.0-21ubuntu1~16.04' --with-bugurl=file:///usr/share/doc/gcc-
7/README.Bugs --enable-languages=c,ada,c++,go,brig,d,fortran,objc,obj-c++
--prefix=/usr --with-gcc-major-version-only --program-suffix=-7
--program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-
id --libexecdir=/usr/lib --without-included-gettext --enable-
threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-
clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-
default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-
verify --enable-libmpx --enable-plugin --with-system-zlib --with-target-
system-zlib --enable-objc-gc=auto --enable-multiarch --disable-werror
--with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32
--enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none
--without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu
--host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 7.3.0 (Ubuntu 7.3.0-21ubuntu1~16.04)
And I want to install gcc-8:
marco@PC:~$ sudo apt-get install gcc-8
[sudo] password for marco:
Reading package lists... Done
Building dependency tree
 gcc-8 : Depends: cpp-8 (= 8.1.0-1ubuntu1) but it is not going to be
installed
         Depends: gcc-8-base (= 8.1.0-1ubuntu1) but 8.1.0-5ubuntu1~16.04
is to be installed
         Depends: libgcc-8-dev (= 8.1.0-1ubuntu1) but it is not going to
be installed
Following the hints found here askUbuntu:Unable to correct problems, you have held broken packages
marco@PC:~$ sudo apt-get update
Hit:1 http://security.ubuntu.com/ubuntu bionic-security InRelease
Hit:2 http://cz.archive.ubuntu.com/ubuntu bionic InRelease
Hit:3 http://us.archive.ubuntu.com/ubuntu bionic InRelease
Get:4 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Hit:5 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease
Fetched 88.7 kB in 1s (107 kB/s)
marco@PC:~$ sudo apt-get autoremove
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
marco@PC:~$ dpkg --get-selections | grep hold
marco@PC:~$ sudo apt-get upgrade
Calculating upgrade... Done
Fetched 88.7 kB in 1s (123 kB/s)
Then, I checked the PPA repository used, as suggested:
marco@PC:~$ apt-cache policy gcc-8 cpp-8 libgcc-8-dev
gcc-8:
  Installed: (none)
  Candidate: 8.1.0-1ubuntu1
  Version table:
     8.1.0-1ubuntu1 500
        500 http://ppa.launchpad.net/ubuntu-toolchain-r/test/ubuntu
bionic/main amd64 Packages
     8-20180414-1ubuntu2 500
        500 http://us.archive.ubuntu.com/ubuntu bionic/universe amd64
Packages
cpp-8:
  Installed: (none)
  Version table:
     8.1.0-1ubuntu1 500
Packages
libgcc-8-dev:
  Installed: (none)
  Version table:
     8.1.0-1ubuntu1 500
        Packages
I then removed the PPA ubuntu-toolchain-r/test :
sudo add-apt-repository --remove ppa:ubuntu-toolchain-r/test
 Toolchain test builds; see https://wiki.ubuntu.com/ToolChain
 More info: https://launchpad.net/~ubuntu-toolchain-r/+archive/ubuntu/test
Press [ENTER] to continue or Ctrl-c to cancel removing it.
But the problem remains:
 gcc-8 : Depends: cpp-8 (= 8-20180414-1ubuntu2) but it is not going to be
installed
         Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.1.0-5ubuntu1~16.04
is to be installed
         Depends: libgcc-8-dev (= 8-20180414-1ubuntu2) but it is not going to
be installed
marco@PC:~$ sudo apt-get install cpp-8
 cpp-8 : Depends: gcc-8-base (= 8.1.0-1ubuntu1) but 8.1.0-5ubuntu1~16.04
 is to be installed
marco@PC:~$ sudo apt-get install gcc-8-base
gcc-8-base is already the newest version (8.1.0-5ubuntu1~16.04).
marco@PC:~$ sudo apt-get install libgcc-8-dev
 libgcc-8-dev : Depends: gcc-8-base (= 8.1.0-1ubuntu1) but
8.1.0-5ubuntu1~16.04 is to be installed
                Depends: libasan5 (>= 8.1.0-1ubuntu1) but it is not going
 to be installed
                Depends: libubsan1 (>= 8.1.0-1ubuntu1) but it is not
 going to be installed
marco@PC:~$ sudo apt-get install libasan5
 libasan5 : Depends: gcc-8-base (= 8.1.0-1ubuntu1) but
marco@PC:~$ sudo apt-get install libubsan1
 libubsan1 : Depends: gcc-8-base (= 8.1.0-1ubuntu1) but
So... it seems that in order to install gcc-8 I have to install other packages which depend on other packages, which depend themself on gcc-8-base, which is already correctly installed.
And it says "broken packages"... so how to solve the problem? Looking forward to your kind hints and help. Marco
Updating:
marco@PC:~$ sudo apt-get install ppa-purge
ppa-purge is already the newest version (0.2.8+bzr63).
marco@PC:~$ sudo ppa-purge ppa:ubuntu-toolchain-r/test
Updating packages lists
PPA to be removed: ubuntu-toolchain-r test
Warning:  Could not find package list for PPA: ubuntu-toolchain-r test
Hit:1 http://cz.archive.ubuntu.com/ubuntu bionic InRelease
Hit:2 http://us.archive.ubuntu.com/ubuntu bionic InRelease
Hit:3 http://security.ubuntu.com/ubuntu bionic-security InRelease
Hit:4 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease
marco@PC:~$ sudo apt install gcc-8-base gcc-8 cpp-8 libgcc-8-dev
 cpp-8 : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.1.0-5ubuntu1~16.04
 is to be installed
 gcc-8 : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.1.0-5ubuntu1~16.04
 is to be installed
 libgcc-8-dev : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but
                 Depends: libasan5 (>= 8-20180414-1ubuntu2) but it is not
                 Depends: libubsan1 (>= 8-20180414-1ubuntu2) but it is not
After installing aptitude I followed the suggestions indicated by aptitude. Now I have this situation:
marco@PC:~$ sudo update-alternatives --config gcc
There are 2 choices for the alternative gcc (providing /usr/bin/gcc).
  Selection    Path            Priority   Status
* 0            /usr/bin/gcc-7   700       auto mode
  1            /usr/bin/gcc-7   700       manual mode
  2            /usr/bin/gcc-8   80        manual mode
 marco@PC:~$ g++ -std=c++17 HelloWorld.cpp -oHelloWorld
marco@PC:~$ ./HelloWorld
Hello World!
If I choose to use gcc-8 :
Press <enter> to keep the current choice[*], or type selection number: 2
update-alternatives: using /usr/bin/gcc-8 to provide /usr/bin/gcc (gcc) in
manual mode
update-alternatives: warning: skip creation of /usr/bin/g++ because
associated file /usr/bin/g++-8 (of link group gcc) doesn't exist
marco@PC:~$ sudo aptitude install g++-8
The following NEW packages will be installed:
  g++-8 libstdc++-8-dev{a}
0 packages upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 9,623 kB of archives. After unpacking 43.7 MB will be used.
Do you want to continue? [Y/n/?] Y
Get: 1 http://us.archive.ubuntu.com/ubuntu bionic/universe amd64 libstdc++-8-
dev amd64 8-20180414-1ubuntu2 [1,536 kB]
Get: 2 http://us.archive.ubuntu.com/ubuntu bionic/universe amd64 g++-8 amd64
8-20180414-1ubuntu2 [8,088 kB]
Fetched 9,623 kB in 1s (7,165 kB/s)
Selecting previously unselected package libstdc++-8-dev:amd64.
(Reading database ... 92421 files and directories currently installed.)
Preparing to unpack .../libstdc++-8-dev_8-20180414-1ubuntu2_amd64.deb ...
Unpacking libstdc++-8-dev:amd64 (8-20180414-1ubuntu2) ...
Selecting previously unselected package g++-8.
Preparing to unpack .../g++-8_8-20180414-1ubuntu2_amd64.deb ...
Unpacking g++-8 (8-20180414-1ubuntu2) ...
Setting up libstdc++-8-dev:amd64 (8-20180414-1ubuntu2) ...
Setting up g++-8 (8-20180414-1ubuntu2) ...
Processing triggers for man-db (2.8.3-2) ...
* 2            /usr/bin/gcc-8   80        manual mode
update-alternatives: warning: forcing reinstallation of alternative /usr/bin
/gcc-8 because link group gcc is broken
Now, after rebooting, it seems working:
Hello World!
marco@PC:~$ gcc -v
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/8/lto-wrapper
8-20180414-1ubuntu2' --with-bugurl=file:///usr/share/doc/gcc-8/README.Bugs
--enable-languages=c,ada,c++,go,brig,d,fortran,objc,obj-c++ --prefix=/usr
--with-gcc-major-version-only --with-as=/usr/bin/x86_64-linux-gnu-as --with-
ld=/usr/bin/x86_64-linux-gnu-ld --program-suffix=-8 --program-prefix=x86_64-
linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib
--without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-
nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-
libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-
object --disable-vtable-verify --enable-libmpx --enable-plugin --enable-
default-pie --with-system-zlib --with-target-system-zlib --enable-objc-
gc=auto --enable-multiarch --disable-werror --with-arch-32=i686 --with-
abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-
tune=generic --enable-offload-targets=nvptx-none --without-cuda-driver
 --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu
Thread model: posix
gcc version 8.0.1 20180414 (experimental) [trunk revision 259383] (Ubuntu
user2315094
  • 247
  • 19
Incompatible repository(s) from 16.04 from in your software sources are interfering with installing other packages in Ubuntu 18.04 and causing an error message about broken packages, so remove those incompatible repositories with ppa-purge from your software sources.
Then you will be able to install the packages that you need from the default Ubuntu 18.04 repositories. Open the terminal and type:
sudo apt update
sudo apt install aptitude
sudo aptitude install libubsan1 libasan5 libgcc-8-dev gcc-8-base gcc-8 cpp-8 g++-8
Follow the suggestions of aptitude if there is a dependency issue after running the last command, because aptitude is a little bit smart about suggesting how to resolve dependency issues that are caused by broken packages.
karel
  • 122,292
  • 133
  • 301
  • 332
