I used terminal window to install IntelliJ at first, which happened without disruption.When I tried for Pycharm instead, it didn't happen. Further I tried it with Ubuntu Software center, and it showed me this message:
Unable to install pycharm CE: snap "pycharm-community" has install-snap change in progress.
Thomas
  • 6,433
If this is still an issue, follow this
-- install snap
command: sudo apt install snapd
-- install pycharm command: sudo snap install pycharm-educational --classic
Once done you'll need to add /snap/bin in the PATH environment variable. (I'll let you know how once i figure it out)
Once done your command to launch pycharm would be pycharm-educational.
