I want ubuntu to read aloud something I put on clipboard. I found a solution for that, which is this:
xsel --clipboard | festival --tts
When I try it on terminal, this code works. But when I try to put this command to a shortcut instead, it doesn't work. Nevertheles, if I change the command in shortcuts with 'gedit' for example, it opens gedit. So, the shortcut is also working. What can be the problem over here?
Keyboard shortcut commands do not get interpreted by a shell, so you can't normally use shell features like pipes in them directly.
Change your shortcut command to explicitly run in a Bash shell:
bash -c 'xsel --clipboard | festival --tts'
Byte Commander
  • 110,243
