11
I want to deploy a war file, to my tomcat manage, and the path is quite long, so I want to enter the path, but whenever I go into open file, I can only select the files manually, by going through the folder. Is there a way to enter the file path, I have attached a picture to show the UI I get (BTW I'm using 16.04)
here is the picture
damadam
  • 2,873
Ctrl + L in the open file dialog will allow you to edit the path.
I normally have a file browser in the destination folder. I use
Ctrl + L and Ctrl + C
to copy the path. Then, in the open file dialog,
Ctrl + L and Ctrl + V
to paste it. Finally
Enter
So the open file dialog goes to that folder.
Katu
  • 3,663
