so I had a dualboot system with Windows 10 and Ubuntu 16.04 on the same disk. On startup I could choose between those two options. Config: sda1 + sda2 windows, sda3 ubuntu sda4 swapp
Now I've formatted the Ubuntu partition and installed Ubuntu Mate 18.04.1. I had to try multiple times, because I could no longer boot into Ubuntu, just into Windows. Since Ubuntu is my main system and windows is "just" for gaming, this was unacceptable. In the Internet there was a recommondation to use a single partition for /boot/efi. That worked. But I cannot boot into Windows anymore. With grub-customiser I've tried to manually boot from sda1 or sda2 with the chainloader option, but it does not boot. boot-repair didn't help me as well.
What can I do?
boot-repair log (the start and suggested repair, couldn't post all of it)
 Boot Info Script 8f991e4 + Boot-Repair extra info      [Boot-Info 25oct2017]
============================= Boot Info Summary: ===============================
 => Grub2 (v2.00) is installed in the MBR of /dev/sda and looks at sector 1 of
    the same hard drive for core.img. core.img is at this location and looks
    for (,msdos7)/boot/grub. It also embeds following components:
    modules
    fshelp ext2 part_msdos biosdisk
 => Grub2 (v2.00) is installed in the MBR of /dev/sdb and looks at sector 1 of
    for /boot/grub. It also embeds following components:
    modules
    fshelp ext2 part_msdos biosdisk search_fs_uuid
    config script
    search.fs_uuid 59884c5a-97a1-4a0d-803b-f08754c18b38 root hd0,msdos7
    set prefix=($root)'/boot/grub'
sda1: __________________________________________________________________________
    File system:       ntfs
    Boot sector type:  Windows 8/2012: NTFS
    Boot sector info:  No errors found in the Boot Parameter Block.
    Operating System:
    Boot files:        /bootmgr /Boot/BCD
sda2: __________________________________________________________________________
    File system:       ntfs
    Operating System:
    Boot files:        /bootmgr /Windows/System32/winload.exe
sda3: __________________________________________________________________________
    File system:       Extended Partition
    Boot sector type:  -
    Boot sector info:
sda5: __________________________________________________________________________
    File system:       vfat
    Boot sector type:  FAT32
    Operating System:
    Boot files:        /EFI/ubuntu/grub.cfg /EFI/BOOT/fbx64.efi
                       /EFI/ubuntu/fwupx64.efi /EFI/ubuntu/grubx64.efi
                       /EFI/ubuntu/mmx64.efi /EFI/ubuntu/shimx64.efi
sda6: __________________________________________________________________________
    File system:       swap
    Boot sector type:  -
    Boot sector info:
sda7: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:  Ubuntu 18.04.1 LTS
    Boot files:        /boot/grub/grub.cfg /etc/fstab
                       /boot/grub/i386-pc/core.img
sdb1: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:
    Boot files:
sdb2: __________________________________________________________________________
    File system:       ntfs
    Boot sector type:  Windows Vista: NTFS
    Operating System:
    Boot files:
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 119.2 GiB, 128035676160 bytes, 250069680 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Partition  Boot  Start Sector    End Sector  # of Sectors  Id System
/dev/sda1    *          2,048       206,847       204,800   7 NTFS / exFAT / HPFS
/dev/sda2             206,848   134,424,575   134,217,728   7 NTFS / exFAT / HPFS
/dev/sda3         134,426,622   250,068,991   115,642,370   5 Extended
/dev/sda5         249,679,872   250,068,991       389,120   b W95 FAT32
/dev/sda6         241,483,776   249,679,871     8,196,096  82 Linux swap / Solaris
/dev/sda7         134,426,624   241,481,727   107,055,104  83 Linux
Drive: sdb _____________________________________________________________________
Disk /dev/sdb: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
/dev/sdb1               2,048   976,562,175   976,560,128  83 Linux
/dev/sdb2         976,562,176 1,953,523,711   976,961,536   7 NTFS / exFAT / HPFS
"blkid" output: ________________________________________________________________
Device           UUID                                   TYPE       LABEL
/dev/loop0                                              squashfs
/dev/loop1                                              squashfs
/dev/loop2                                              squashfs
/dev/loop3                                              squashfs
/dev/loop4                                              squashfs
/dev/loop5                                              squashfs
/dev/sda1        2A305B70305B424D                       ntfs       System-reserviert
/dev/sda2        DE3C69153C68EA4B                       ntfs
/dev/sda5        9B1A-75A3                              vfat
/dev/sda6        676623b7-4e0b-4ed9-a0a9-22f6dc833e98   swap
/dev/sda7        59884c5a-97a1-4a0d-803b-f08754c18b38   ext4
/dev/sdb1        aeed298b-9fde-4f02-a35e-a40d56ed5fe5   ext4
/dev/sdb2        2FC71E081224AF73                       ntfs       windata
========================= "ls -l /dev/disk/by-id" output: ======================
total 0
lrwxrwxrwx 1 root root  9 Aug 30 19:53 ata-HL-DT-ST_DVDRAM_GH24NS95_K51CBNB2036 -> ../../sr0
lrwxrwxrwx 1 root root  9 Aug 30 21:06 ata-M4-CT128M4SSD2_0000000013020924D0E6 -> ../../sda
lrwxrwxrwx 1 root root 10 Aug 30 21:06 ata-M4-CT128M4SSD2_0000000013020924D0E6-part1 -> ../../sda1
lrwxrwxrwx 1 root root 10 Aug 30 21:06 ata-M4-CT128M4SSD2_0000000013020924D0E6-part2 -> ../../sda2
lrwxrwxrwx 1 root root 10 Aug 30 21:06 ata-M4-CT128M4SSD2_0000000013020924D0E6-part3 -> ../../sda3
lrwxrwxrwx 1 root root 10 Aug 30 21:06 ata-M4-CT128M4SSD2_0000000013020924D0E6-part5 -> ../../sda5
lrwxrwxrwx 1 root root 10 Aug 30 21:06 ata-M4-CT128M4SSD2_0000000013020924D0E6-part6 -> ../../sda6
lrwxrwxrwx 1 root root 10 Aug 30 21:06 ata-M4-CT128M4SSD2_0000000013020924D0E6-part7 -> ../../sda7
lrwxrwxrwx 1 root root  9 Aug 30 21:06 ata-ST1000DM003-1CH162_S1D7T6XN -> ../../sdb
lrwxrwxrwx 1 root root 10 Aug 30 21:06 ata-ST1000DM003-1CH162_S1D7T6XN-part1 -> ../../sdb1
lrwxrwxrwx 1 root root 10 Aug 30 21:06 ata-ST1000DM003-1CH162_S1D7T6XN-part2 -> ../../sdb2
lrwxrwxrwx 1 root root  9 Aug 30 21:06 wwn-0x5000c5005be2ac23 -> ../../sdb
lrwxrwxrwx 1 root root 10 Aug 30 21:06 wwn-0x5000c5005be2ac23-part1 -> ../../sdb1
lrwxrwxrwx 1 root root 10 Aug 30 21:06 wwn-0x5000c5005be2ac23-part2 -> ../../sdb2
lrwxrwxrwx 1 root root  9 Aug 30 19:53 wwn-0x5001480000000000 -> ../../sr0
lrwxrwxrwx 1 root root  9 Aug 30 21:06 wwn-0x500a07510924d0e6 -> ../../sda
lrwxrwxrwx 1 root root 10 Aug 30 21:06 wwn-0x500a07510924d0e6-part1 -> ../../sda1
lrwxrwxrwx 1 root root 10 Aug 30 21:06 wwn-0x500a07510924d0e6-part2 -> ../../sda2
lrwxrwxrwx 1 root root 10 Aug 30 21:06 wwn-0x500a07510924d0e6-part3 -> ../../sda3
lrwxrwxrwx 1 root root 10 Aug 30 21:06 wwn-0x500a07510924d0e6-part5 -> ../../sda5
lrwxrwxrwx 1 root root 10 Aug 30 21:06 wwn-0x500a07510924d0e6-part6 -> ../../sda6
lrwxrwxrwx 1 root root 10 Aug 30 21:06 wwn-0x500a07510924d0e6-part7 -> ../../sda7
================================ Mount points: =================================
Device           Mount_Point              Type       Options
/dev/sda1        /media/micha/System-reserviert fuseblk    (ro,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096,uhelper=udisks2)
/dev/sda2        /media/micha/DE3C69153C68EA4B fuseblk    (ro,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096,uhelper=udisks2)
/dev/sda5        /media/micha/9B1A-75A3   vfat       (rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,showexec,utf8,flush,errors=remount-ro,uhelper=udisks2)
/dev/sda7        /                        ext4       (rw,relatime,errors=remount-ro,data=ordered)
/dev/sdb1        /home                    ext4       (rw,relatime,data=ordered)
/dev/sdb2        /media/micha/windata     fuseblk    (ro,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096,uhelper=udisks2)
========================== sda5/EFI/ubuntu/grub.cfg: ===========================
configfile $prefix/grub.cfg
=========================== sda7/boot/grub/grub.cfg: ===========================
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
  set have_grubenv=true
  load_env
fi
if [ "${next_entry}" ] ; then
   set default="${next_entry}"
   set next_entry=
   save_env next_entry
   set boot_once=true
else
   set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
  menuentry_id_option="--id"
else
  menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
  fi
function recordfail {
  set recordfail=1
  if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
  if [ x$feature_all_video_module = xy ]; then
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
if [ x$feature_default_font_path = xy ] ; then
   font=unicode
else
insmod part_msdos
insmod ext2
set root='hd0,msdos7'
if [ x$feature_platform_search_hint = xy ]; then
  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos7 --hint-efi=hd0,msdos7 --hint-baremetal=ahci0,msdos7  59884c5a-97a1-4a0d-803b-f08754c18b38
else
  search --no-floppy --fs-uuid --set=root 59884c5a-97a1-4a0d-803b-f08754c18b38
fi
    font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
  set gfxmode=auto
  load_video
  insmod gfxterm
  set locale_dir=$prefix/locale
  set lang=de_DE
  insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ] ; then
  set timeout=30
else
  if [ x$feature_timeout_style = xy ] ; then
    set timeout_style=menu
    set timeout=10
  # Fallback normal timeout code in case the timeout_style feature is
  # unavailable.
  else
    set timeout=10
  fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
if background_color 60,59,55; then
  clear
fi
color_normal=light-gray/black
if [ -e ${prefix}/themes/ubuntu-mate/theme.txt ]; then
  insmod png
  theme=${prefix}/themes/ubuntu-mate/theme.txt
fi
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
    set gfxpayload="${1}"
    if [ "${1}" = "keep" ]; then
        set vt_handoff=vt.handoff=1
    else
        set vt_handoff=
    fi
if [ "${recordfail}" != 1 ]; then
  if [ -e ${prefix}/gfxblacklist.txt ]; then
    if hwmatch ${prefix}/gfxblacklist.txt 3; then
      if [ ${match} = 0 ]; then
        set linux_gfx_mode=keep
      else
        set linux_gfx_mode=text
      fi
    else
    fi
  else
  fi
else
fi
export linux_gfx_mode
menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-59884c5a-97a1-4a0d-803b-f08754c18b38' {
    recordfail
    load_video
    gfxmode $linux_gfx_mode
    insmod gzio
    if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
    insmod part_msdos
    insmod ext2
    else
    fi
        linux   /boot/vmlinuz-4.15.0-33-generic root=UUID=59884c5a-97a1-4a0d-803b-f08754c18b38 ro  quiet splash $vt_handoff
    initrd  /boot/initrd.img-4.15.0-33-generic
submenu 'Erweiterte Optionen für Ubuntu' $menuentry_id_option 'gnulinux-advanced-59884c5a-97a1-4a0d-803b-f08754c18b38' {
    menuentry 'Ubuntu, mit Linux 4.15.0-33-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.15.0-33-generic-advanced-59884c5a-97a1-4a0d-803b-f08754c18b38' {
        recordfail
        load_video
        insmod gzio
        insmod part_msdos
        insmod ext2
        else
        fi
        echo    'Linux 4.15.0-33-generic wird geladen …'
        echo    'Initiale Ramdisk wird geladen …'
    menuentry 'Ubuntu, mit Linux 4.15.0-33-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.15.0-33-generic-recovery-59884c5a-97a1-4a0d-803b-f08754c18b38' {
        recordfail
        load_video
        insmod gzio
        insmod part_msdos
        insmod ext2
        else
        fi
            linux   /boot/vmlinuz-4.15.0-33-generic root=UUID=59884c5a-97a1-4a0d-803b-f08754c18b38 ro recovery nomodeset
    menuentry 'Ubuntu, mit Linux 4.15.0-32-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.15.0-32-generic-advanced-59884c5a-97a1-4a0d-803b-f08754c18b38' {
        recordfail
        load_video
        insmod gzio
        insmod part_msdos
        insmod ext2
        else
        fi
        echo    'Linux 4.15.0-32-generic wird geladen …'
            linux   /boot/vmlinuz-4.15.0-32-generic root=UUID=59884c5a-97a1-4a0d-803b-f08754c18b38 ro  quiet splash $vt_handoff
        initrd  /boot/initrd.img-4.15.0-32-generic
    menuentry 'Ubuntu, mit Linux 4.15.0-32-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.15.0-32-generic-recovery-59884c5a-97a1-4a0d-803b-f08754c18b38' {
        recordfail
        load_video
        insmod gzio
        insmod part_msdos
        insmod ext2
        else
        fi
            linux   /boot/vmlinuz-4.15.0-32-generic root=UUID=59884c5a-97a1-4a0d-803b-f08754c18b38 ro recovery nomodeset
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
menuentry 'System setup' $menuentry_id_option 'uefi-firmware' {
    fwsetup
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
menuentry "Windows sda1"{
    set root='(hd0,1)'
    search --no-floppy --fs-uuid --set 2A305B70305B424D
    drivemap -s (hd0) ${root}
    chainloader +1
menuentry "Windows sda2"{
    set root='(hd0,2)'
    search --no-floppy --fs-uuid --set DE3C69153C68EA4B
    chainloader +1
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f  ${config_directory}/custom.cfg ]; then
  source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f  $prefix/custom.cfg ]; then
  source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
=================== Suggested repair
The default repair of the Boot-Repair utility would reinstall the grub2 of sda7 into the MBRs of all disks (except live-disks and removable disks without OS).
Grub-efi would not be selected by default because: no-win-efi
Additional repair would be performed: unhide-bootmenu-10s   fix-windows-boot
Thomas Ward
  • 78,878
Omega19
