I'm running into a rather confusing issue with server certificate verifications. When running apt update I get the following error:
W: Failed to fetch https://deb.nodesource.com/node_6.x/dists/trusty/main/binary-amd64/Packages  server certificate verification failed. CAfile: none CRLfile: none
W: Failed to fetch https://packages.gitlab.com/gitlab/gitlab-ce/ubuntu/dists/trusty/main/source/Sources  server certificate verification failed. CAfile: none CRLfile: none
And also when I try to clone a Git repository, I get: fatal: unable to access 'https://github.com/certbot/certbot/': server certificate verification failed. CAfile: none CRLfile: none
The operating system is Ubuntu 14.04.5 LTS.
I tried reinstalling the ca-certificates and adding extra certificates from other sources and updating the certificates by running update-ca-certificates.
This problem just happened to spontaneously appear from all I could tell.
Hopefully somebody can help me out with this. Thanks!
Arronical
  • 20,241
Sietse
I managed to work around the issue my specifically ignoring server certificate verification for now in APT. By adding some custom configuration in /etc/apt/apt.conf.d.
In case of Gitlab: Acquire::https::packages.gitlab.com::Verify-Peer "false";
For the Git issues I used the GIT_SSL_NO_VERIFY environment variable whenever accessing the repository.
It's not a solution per se, but this way I can at least keep using the repo's. :-)
Sietse
