I upgraded to Ubuntu 18.04 and now the Wine program is broken. When I tried to uninstall it (so I could reinstall it from scratch), I get a circular dependency.
joseph@joseph-Lenovo-Y50-70:~$ sudo apt-get remove wine1.8
[sudo] password for joseph:
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
wine1.8-amd64 : Depends: wine1.8:any (= 1:1.8.0-
0ubuntu1~ubuntu15.10.1~ppa1)
Recommends: libgif4 but it is not installable
Recommends: libgnutls26 but it is not installable
Recommends: wine-gecko2.34 but it is not installable
Recommends: wine-mono4.5.4 but it is not installable
wine1.8-i386:i386 : Depends: wine1.8:any (= 1:1.8.0-
Recommends: libgif4:i386 but it is not
installable
Recommends: libgnutls26:i386 but it is not
installable
Recommends: wine-gecko2.34:i386 but it is not
installable
Recommends: wine-mono4.5.4:i386 but it is not
installable
wine32:i386 : Depends: libwine:i386 (= 3.0-1ubuntu1) but it is not
going to be installed
Recommends: wine-stable:i386 (= 3.0-1ubuntu1)
wine64 : Depends: libwine (= 3.0-1ubuntu1) but it is not going to
be installed
Recommends: wine-stable (= 3.0-1ubuntu1) but it is not going
to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no
packages (or specify a solution).
joseph@joseph-Lenovo-Y50-70:~$ sudo apt-get remove wine1.8-amd64
wine1.8 : Depends: wine1.8-amd64 (= 1:1.8.0-
Recommends: fonts-droid but it is not installable
Recommends: winetricks but it is not going to be installed
be installed
to be installed
When I then follow the instructions to fix the broken install with apt --fix-broken install, I get the following:
The following additional packages will be installed:
fonts-wine libwine libwine:i386
The following NEW packages will be installed:
0 upgraded, 3 newly installed, 0 to remove and 1 not upgraded.
21 not fully installed or removed.
Need to get 0 B/39.9 MB of archives.
After this operation, 375 MB of additional disk space will be
used.
Do you want to continue? [Y/n] y
(Reading database ... 667404 files and directories currently
installed.)
Preparing to unpack .../libwine_3.0-1ubuntu1_i386.deb ...
Unpacking libwine:i386 (3.0-1ubuntu1) ...
dpkg: error processing archive
/var/cache/apt/archives/libwine_3.0-
1ubuntu1_i386.deb (--unpack):
trying to overwrite '/usr/lib/i386-linux-gnu/wine/acledit.dll.so',
which is also in package wine1.8-i386:i386 1:1.8.0-
dpkg-deb: error: paste subprocess was killed by signal (Broken
pipe)
Preparing to unpack .../libwine_3.0-1ubuntu1_amd64.deb ...
Unpacking libwine:amd64 (3.0-1ubuntu1) ...
1ubuntu1_amd64.deb (--unpack):
trying to overwrite '/usr/lib/x86_64-linux-
gnu/wine/acledit.dll.so', which is also in package wine1.8-amd64
1:1.8.0-0ubuntu1~ubuntu15.10.1~ppa1
pipe)
Selecting previously unselected package fonts-wine.
Preparing to unpack .../fonts-wine_3.0-1ubuntu1_all.deb ...
Unpacking fonts-wine (3.0-1ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/fonts-
wine_3.0-1ubuntu1_all.deb (--unpack):
trying to overwrite '/usr/share/wine/fonts/coue1255.fon', which is
also in package wine1.8 1:1.8.0-0ubuntu1~ubuntu15.10.1~ppa1
pipe)
/var/cache/apt/archives/libwine_3.0-1ubuntu1_i386.deb
/var/cache/apt/archives/libwine_3.0-1ubuntu1_amd64.deb
/var/cache/apt/archives/fonts-wine_3.0-1ubuntu1_all.deb
I've already tried the steps here How to remove wine completely but it didn't help...
