any one knows how can i install MuMuDVB 2.0.0 on ubuntu?
http://mumudvb.net/download/
dufte
  • 14,198
  • 41
  • 43
Opatan
Option 1. Install via APT
According to https://packages.ubuntu.com/search?suite=trusty&searchon=names&keywords=mumudvb the MuMuDVB package is available for 14.04 via APT.
So simply open up a terminal and run the following commands:
sudo apt update
sudo apt install mumudvb
This should result in version 1.7.1 at the moment.
Regaring different ubuntu-versions:
  • 14.04
  • 16.04
  • 18.04
all featuring mumudvb 1.7.1 right now.
Option 2: Installing .deb manually:
In case you are willing to install a local .deb file manually, follow this steps
  • On Terminal
  • Navigate to the location where your .deb is located
  • Enter sudo dpkg -i NameOfLocalDebFile.deb
Option 3: Compile
If you need a particular newer version consider checking the project website and compile the source yourself.
dufte
  • 14,198
  • 41
  • 43
