I installed java default packages in Ubuntu 18.04 and tried to install Jenkins. When this did not work I searched for reasons for this and found that Jenkins needs Java 8 and the default Java in Ubuntu 18.04 is Java 10.
So, I removed all the files of Java from /usr/lib/jre folder and tried to install Java 8. It says they are already installed without downloading packages and when I tried to verify the version it said JAVA NOT FOUND.
How could I solve this issue?
Zanna
  • 72,312
Why to install and make it complicated?
Instead of installing Jenkins using package manager sudo apt install, a better option is run Jenkins as war.
  1. Download the latest stable Jenkins WAR file to an appropriate directory on your machine.
  2. Open up a terminal/command prompt window to the download directory.
  3. Run the command java -jar jenkins.war.
  4. Browse to http://localhost:8080 and wait until the Unlock Jenkins page appears.
By default Jenkins runs on port 8080, change port using java -jar jenkins.war --httpPort=9090
To keep jenkins running on Ubuntu even after terminal is closed, use
nohup java -jar jenkins.war --httpPort=9090 &
See Installing Jenkins for more options.
r_D
  • 151
I had the same issue.
Info in repositories is not right.
If you follow logs you'll find the version you're installing is an archive. For me it was u191 today: 2019/01/16 but on website it's u201 or u202.
you have to change your repo info like this:
cd /var/lib/dpkg/info
sudo sed -i 's|JAVA_VERSION=8u191|JAVA_VERSION=8u201|' oracle-java8-installer.*
sudo sed -i 's|PARTNER_URL=http://download.oracle.com/otn-pub/java/jdk/8u191-b12/2787e4a523244c269598db4e85c51e0c/|PARTNER_URL=https://download.oracle.com/otn-pub/java/jdk/8u201-b09/42970487e3af4f5aa5bca3f542482c60/|' oracle-java8-installer.*
sudo sed -i 's|SHA256SUM_TGZ="53c29507e2405a7ffdbba627e6d64856089b094867479edc5ede4105c1da0d65"|SHA256SUM_TGZ="cb700cc0ac3ddc728a567c350881ce7e25118eaf7ca97ca9705d4580c506e370"|' oracle-java8-installer.*
sudo sed -i 's|J_DIR=jdk1.8.0_191J_DIR=jdk1.8.0_201|' oracle-java8-installer.*
Information is on Oracle's download website.
See answers to Can't install Oracle Java 8 in Ubuntu 16.04
Zanna
  • 72,312
