13
Is there a way to show flags instead of labels in the language indicator in the top panel, in gnome-shell (3.28)?
I found this setting in dconf-editor: /org/gnome/libgnomekbd/indicator/show-flags But it's ineffective, nothing changes if I set that to true.
Is there a way to do this?
pomsky
  • 70,557
Jimmy Scionti
  • 182
Here is a hacky workaround.
You need to change the abbreviations of layouts (e.g. "en") shown in the keyboard layout indicator of GNOME top bar following this very detailed answer by @MathCubes.
As mentioned in the answer the <shortDescription> tags in the /usr/share/X11/xkb/rules/evdev.xml file dictate the abbreviations. Change the <shortDescription> labels associated to your chosen layouts (e.g. en) to suitable flag emojis (you can get them from Get Emoji or Emojipedia).
Since GNOME shell v3.28 supports global colour emojis, you should see coloured flags instead of labels after you reboot or re-login or restart the GNOME Shell.
Example:
(after replacing en by for the "English (UK)" layout)
pomsky
  • 70,557
✅ I made this extension exactly for that: https://github.com/jasursadikov/gnome-language-flags Thanks @pomsky for the reference.
