My Ubuntu installation does not boot when I remove a non relevant HDD (sda) from my system. Instead I am stuck in initramfs. However if it is connected it starts up just fine from sdb3.
  • sda unallocated - the hdd required to boot for whatever reason
  • sdb3 /
  • sdb5 swap
  • sdb6 home
It might be worth mentioning that I tried to clone sdb as is to sda using clonezilla live which failed. So sda has no partitions, but if I boot from sda grub rescue appears.
UUIDs of blkid -l match those of fstab
initramfs-tool/conf.d/resume points to sdb5
GRUB and initramfs were updated several times
fsck.ext4 /dev/sdb3 was run several times from live with no errors
Any help would be appreciated since this is my main driver and the problem doesn't seem too severe.
Zanna
  • 72,312
maxwhere
  • 111
Ok i found the solution for my particular problem: Apparaently cloning the existing partitions to a new hdd via clonezilla beforehand somehow mashed up my kernel boot commands - which were for some reason set to drive letters instead to UUIDs in grub
Lesson learned: always check for every parameter involved.
Thank you Panther for your time and effort.
maxwhere
  • 111
