Since upgrading to 18.04 from 16.04 I have been seeing the following message:
➜  ~ hwe-support-status
You have packages from the Hardware Enablement Stack (HWE) installed that
are going out of support on 2023-04-30.
To upgrade to a supported (or longer-supported) configuration:
* Upgrade from Ubuntu 16.04 LTS to Ubuntu 18.04 LTS by running:
sudo do-release-upgrade -p
OR
* Switch to the current security-supported stack by running:
sudo apt-get install linux-generic-hwe-18.04
and reboot your system.
➜  ~ hwe-support-status --show-all-unsupported
➜  ~ hwe-support-status --show-replacements
➜  ~ sudo apt-get install linux-generic-hwe-18.04
Reading package lists... Done
Building dependency tree
E: Unable to locate package linux-generic-hwe-18.04
E: Couldn't find any package by glob 'linux-generic-hwe-18.04'
E: Couldn't find any package by regex 'linux-generic-hwe-18.04'
➜  ~ sudo do-release-upgrade -p
Checking for a new Ubuntu release
No new release found.
➜  ~ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.1 LTS
Release:        18.04
Codename:       bionic
Does anyone know why this is happening?
Chris
  • 91
No specific hwe or lts linux-image is yet required for 18.04 (so it doesn't exists). Ensure first that linux-image-generic image is installed:
 apt install linux-image-generic
Then remove old hwe or lts linux images, in my case I did:
apt purge linux-image-generic-lts-xenial
Then the hwe-support-status command returns a clean empty response.
Laurent
  • 666
I had an old unsupported Linux kernel installed, discovered using
# apt policy linux-generic\*
Remember to run
# apt autoremove
to remove any unused dependencies which may also be picked up by hwe-support-status.
Chris
  • 91
