Just remove (I would prefer with force option enabled) the file - $i:
#!/bin/bash
echo -e "$NAUTILUS_SCRIPT_SELECTED_FILE_PATHS" | find '*.mp4'
for i in *.mp4
do
ffmpeg -i "$i" -c:v copy -c:a pcm_s16le -ar 48000 -ac 2 "$(echo "$i"|cut -d\. -f1).mov"
rm -f "$i"
done
- If you wish you can replace the newlines with semicolon
; sign.
Another option is to move the file to the trash instead of delete it:
gvfs-trash "$i"
In addition, your script can be improved in the following way:
#!/bin/bash -e
# Get the items selected in Nautilus as an array
IFS_BAK=$IFS
IFS=$'\t\n'
FILE_LIST=($NAUTILUS_SCRIPT_SELECTED_FILE_PATHS)
IFS=$IFS_BAK
# For each item in the array $FILE_LIST
for ((i=0; i<${#FILE_LIST[@]}; i++))
do
# Get the file extension
FILE_EXT="${FILE_LIST[$i]##*.}"
# If the item is a file and its extension is mp4
if [[ -f ${FILE_LIST[$i]} ]] && [[ $FILE_EXT == 'mp4' ]]
then
# Get the filename
FILE_NAME="${FILE_LIST[$i]%.*}"
# Compose the name of the new file
THE_NEW_FILE="${FILE_NAME}.mov"
# Do the conversion
ffmpeg -i "${FILE_LIST[$i]}" -c:v copy -c:a pcm_s16le -ar 48000 -ac 2 "$THE_NEW_FILE"
# Remove the item: rm -f "${FILE_LIST[$i]}"; or move it to the trash:
gvfs-trash "${FILE_LIST[$i]}"
# Output a message, note ##*/ will remove the path from the filename
notify-send "mp4 to mov" "${THE_NEW_FILE##*/} - was created\n${FILE_LIST[$i]##*/} - was moved to the Тrash"
fi
done
Here is one related question: Script to merge Video and subs then delete the existing files
