I have a new machine which I'm setting up as my LAN router using the 18.04 server release, to provide DHCP and bind services to my LAN, firewalling, NAT'ing, internet access etc.
It has 2 ethernet NICs and one of them is connected to my Draytek ADSL modem which requires ppp.
I've installed everything that I think I need but my configuration is obviously wrong since ppp can't build an internet connection.
Going by this answer How do I use netplan to configure PPPoE? it should be relatively easy, but the answer omits the crucial info that I'm after, i.e. what to put in the netplan yaml - or whatever else it is that I'm missing.
I may have caused the problem myself by installing xubuntu-core to provide a minimal desktop / window manager GUI for ease of surfing the net while working on it. I fear it introduced network-manager although I'm not sure.
This is my netplan yaml:
adam@gondolin:~$ cat /etc/netplan/01-netcfg.yaml
# This file describes the network interfaces available on your system
# For more information, see netplan(5).
network:
version: 2
renderer: networkd
ethernets:
enp5s0:
dhcp4: yes
enp0s31f6:
dhcp4: no
dhcp6: no
adam@gondolin:~$
I have the enp5s0interface set to use DHCP so that I can get onto the LAN and access the internet while I'm prepping this server, although when it is ready, that interface will be the router's interface for the LAN with a fixed IP address 192.168.0.3.
This is the ifconfig -a output:
adam@gondolin:~$ ifconfig -a
enp0s31f6: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether e0:d5:5e:62:97:4c txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 16 memory 0xf7400000-f7420000
enp5s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.228 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::e2d5:5eff:fe62:974e prefixlen 64 scopeid 0x20<link>
ether e0:d5:5e:62:97:4e txqueuelen 1000 (Ethernet)
RX packets 5561 bytes 431753 (431.7 KB)
RX errors 0 dropped 898 overruns 0 frame 0
TX packets 4462 bytes 1871915 (1.8 MB)
device memory 0xf7200000-f721ffff
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 9479 bytes 757999 (757.9 KB)
TX packets 9479 bytes 757999 (757.9 KB)
wlp6s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.230 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::39c6:9a99:7b58:1cf1 prefixlen 64 scopeid 0x20<link>
ether 00:e1:8c:75:39:d3 txqueuelen 1000 (Ethernet)
RX packets 29 bytes 4677 (4.6 KB)
TX packets 64 bytes 9172 (9.1 KB)
adam@gondolin:~$
which displays the info about the wifi interface too - another suspicious sign but I am not using it - is disabling it in netplan a good idea? (and how?)
And this is the output of networkctl:
adam@gondolin:~$ networkctl
IDX LINK TYPE OPERATIONAL SETUP
1 lo loopback carrier unmanaged
2 enp5s0 ether routable configured
3 enp0s31f6 ether off unmanaged
4 wlp6s0 wlan routable unmanaged
4 links listed.
adam@gondolin:~$
Here's the syslog error from trying to start ppp:
Aug 26 22:03:10 localhost pppd[10297]: Plugin rp-pppoe.so loaded.
Aug 26 22:03:10 localhost pppd[10298]: pppd 2.4.7 started by adam, uid 0
Aug 26 22:03:10 localhost pppd[10298]: error sending pppoe packet: Network is down
Aug 26 22:03:10 localhost pppd[10298]: error receiving pppoe packet: Network is down
Aug 26 22:03:15 localhost pppd[10298]: error sending pppoe packet: Network is down
Aug 26 22:03:25 localhost pppd[10298]: error sending pppoe packet: Network is down
Aug 26 22:03:45 localhost pppd[10298]: Timeout waiting for PADO packets
Aug 26 22:03:45 localhost pppd[10298]: Unable to complete PPPoE Discovery
Aug 26 22:03:51 localhost pppd[10298]: Terminating on signal 15
Aug 26 22:03:51 localhost pppd[10298]: Exit.
Finally, here's my /etc/ppp/peers/provider:
adam@gondolin:~$ cat /etc/ppp/peers/provider
# See the manual page pppd(8) for information on all the options.
# There should be a matching entry with the password in /etc/ppp/pap-secrets
# and/or /etc/ppp/chap-secrets.
user "adam.xxxxx@xxxxxxx-xxxx.com"
hide-password
plugin rp-pppoe.so nic-enp0s31f6
# MUST CHANGE: replace ******** with the phone number of your provider.
# The /etc/chatscripts/pap chat script may be modified to change the
# modem initialization string.
#connect "/usr/sbin/chat -v -f /etc/chatscripts/pap -T ********"
# Serial device to which the modem is connected.
#/dev/modem
# Speed of the serial line.
#115200
# Assumes that your IP address is allocated dynamically by the ISP.
noipdefault
# Don't try to get the name server addresses from the ISP - messes up local name resolution
#usepeerdns
# Use this connection as the default route.
defaultroute
replacedefaultroute
# Makes pppd "dial again" when the connection is lost.
persist
# Do not ask the remote to authenticate.
noauth
adam@gondolin:~$
I also see a stream of logging in syslog on boot showing that something is resurrecting network-manager despite the fact that I disabled it with sudo systemctl disable network-manager
