12
Hi I've just installed Ubuntu 18.04 When I go to settings / online accounts and click Ubuntu Single Sing-ON and input the correct credentials it just hangs on "Connecting..." and doesn't do anything. If I put incorrect details in however It almost immediately tells me that the credentials are incorrect. Is this a bug or me being silly and is there a work around?
Thanks For any help.
Ben Welsh
  • 121
Try removing any existing Ubuntu accounts and adding them again. That simple step worked for me.
You should be getting a message about authorising the snap daemon (which asks for your local root user password). If not, check if snap works:
snap login
If you don't have snap, there might be something wrong with your Ubuntu (it should be included by default). Snap can, however, be installed:
sudo apt install snapd
If you still cannot add your account, but you only wanted to enable canonical-livepatch, try activating it from terminal:
sudo snap install canonical-livepatch
sudo canonical-livepatch enable <key>
replace < key > with your live-patch key, which can be generated from:
https://www.ubuntu.com/livepatch
Then go open 'software & updates', click on the 'updates' tab, and enable livepatch
Aswin B
  • 111
With 20.04, I found that the livepatch URL above redirects to Ubuntu Advantage and that when you click the green button "Get Ubuntu Advantage" then you can create a free key but the command to enable livepatch is different:
sudo ua attach <key>
Chris Eich
