I've decided to install Ubuntu alongside Windows 10 and I'm trying to follow these instructions.
After I'm done with the installation process, a window pops up that says I need to restart Ubuntu. I click on "restart now" (or something like this) and get a screen with the following:
[ 0.000000] [Firmware Bug]: TSC_DEADLINE disabled due to Errata; please update microcode to version 0xb2 (or later)
[ 1579.737040] reboot: Restarting system
And that's it. Nothing happens.
Sorry if this issue is easy to solve, I'm an inexperienced user and googling didn't get me anywhere.
Edit: the first error does not seem to be the problem, because it's not a fatal error which would prevent Ubuntu from booting
abu_bua
  • 11,313
You should manually restart your system (using the hardware button or power cycle).
The first message, that TSC_DEADLINE is disabled, is a problem but not a fatal one. It is not interfering with boot, reboot, or shutdown. TSC is a "nice to have," not a "must have". See the good discussion of this error on the unix StackExchange.
Note that the instructions you followed assume some things about your computer (in particular, that it is a newish machine with a UEFI BIOS). That's probably totally right for you, but if not you may have some trouble booting. Good luck!
Matt
  • 121
start your system in non graphical mode or in recovery mode and install the microcode
For Intel
sudo apt-get install intel-microcode #(to install )
sudo apt-get upgrade intel-microcode #(to upgrade )
For AMD
sudo apt-get install amd64-microcode #( to install )
sudo apt-get upgrade amd64-microcode #( to upgrade )
If this not help update your BIOS
Check your system by running command iucode-tool --scan-system , sudo dmidecode -t bios -q and cat /proc/cpuinfo | grep 'microcode' and post the result
