I recently upgraded to Ubuntu 18.04 and the DVD player stopped working. After some research I was trying to reinstall gstreamer but I ran into an issue that seems related to Ubuntu 18.04 and that is beyond my understanding. Here is the output of the command:
$ sudo apt-get install gstreamer1.0-tools gstreamer1.0-alsa gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-libav
Reading package lists... Done
Building dependency tree
gstreamer1.0-plugins-base is already the newest version (1.14.1-1ubuntu1~ubuntu18.04.1).
gstreamer1.0-plugins-base set to manually installed.
gstreamer1.0-libav is already the newest version (1.14.1-1~ubuntu18.04.1).
gstreamer1.0-tools is already the newest version (1.14.1-1~ubuntu18.04.1).
gstreamer1.0-tools set to manually installed.
gstreamer1.0-plugins-ugly is already the newest version (1.14.1-1~ubuntu18.04.1).
gstreamer1.0-plugins-good is already the newest version (1.14.1-1ubuntu1~ubuntu18.04.1).
gstreamer1.0-plugins-good set to manually installed.
gstreamer1.0-alsa is already the newest version (1.14.1-1ubuntu1~ubuntu18.04.1).
gstreamer1.0-alsa set to manually installed.
 gstreamer1.0-plugins-bad : Depends: libgstreamer-plugins-bad1.0-0 (= 1.14.0-1ubuntu1) but 1.14.1-1ubuntu1~ubuntu18.04.1 is to be installed
Any help is really appreciated (in particular by the kids :) )
Zanna
  • 72,312
Ste
  • 156
I had some struggle with it too, but I found a .deb package which solved the problem:
From https://launchpad.net/~ci-train-ppa-service/+archive/ubuntu/3267-deletedppa/+build/14926540 download the
gstreamer1.0-plugins-bad_1.14.1-1ubuntu1~ubuntu18.04.1_amd64.deb
and install it.
