I have enabled the Nvidia graphics driver ppa and I have the 390 drivers installed.
I am trying to upgrade to the 396 drivers but I am running into difficulties.
The normal way I've installed the nvidia graphics drivers is by installing the package named 'nvidia-390'. The first thing I noticed is that there isn't a package called 'nvidia-396'. However there is a package called 'nvidia-driver-396'. When I try and install that however I get the following error message.
jamie@jamie-ncase:~$ sudo apt install nvidia-driver-396
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
nvidia-driver-396 : Depends: nvidia-dkms-396 (= 396.54-0ubuntu0~gpu18.04.1) but it is not going to be installed
Depends: libnvidia-decode-396 (= 396.54-0ubuntu0~gpu18.04.1) but it is not going to be installed
Depends: libnvidia-encode-396 (= 396.54-0ubuntu0~gpu18.04.1) but it is not going to be installed
Depends: nvidia-utils-396 (= 396.54-0ubuntu0~gpu18.04.1) but it is not going to be installed
Depends: xserver-xorg-video-nvidia-396 (= 396.54-0ubuntu0~gpu18.04.1) but it is not going to be installed
Depends: libnvidia-cfg1-396 (= 396.54-0ubuntu0~gpu18.04.1) but it is not going to be installed
Depends: libnvidia-fbc1-396 (= 396.54-0ubuntu0~gpu18.04.1) but it is not going to be installed
Recommends: libnvidia-decode-396:i386 (= 396.54-0ubuntu0~gpu18.04.1)
Recommends: libnvidia-encode-396:i386 (= 396.54-0ubuntu0~gpu18.04.1)
Recommends: libnvidia-ifr1-396:i386 (= 396.54-0ubuntu0~gpu18.04.1)
Recommends: libnvidia-fbc1-396:i386 (= 396.54-0ubuntu0~gpu18.04.1)
Recommends: libnvidia-gl-396:i386 (= 396.54-0ubuntu0~gpu18.04.1)
The thing is i'm pretty sure I don't have broken packages unless I try and install this new driver: I can run 'sudo apt update' and 'sudo apt dist-upgrade' no problem, both run fine.
