Every time I install playonlinux and then on installing windows software when playonlinux automatically installs wine, Brackets gets uninstalled.
The command
sudo apt install brackets
is unable to install Brackets.
However on using the command
sudo apt install snapd
sudo snap install brackets
it says
My system may be at risk upon installing, if I understand what I am doing I may proceed using the command
sudo snap install brackets --classic
Upon giving this command it successfully installs Brackets.
But again if I install another windows software again Brackets gets uninstalled and I have to again install Brackets using snap command.
So why this happens?
I do not remember the exact terminal error prompt.
Also why my system may be at risk?
Sonevol
  • 696
Brackets gets uninstalled every time you install Windows software on PlayOnLinux because of a permissions issue that occurs because Brackets snap package was not installed correctly to begin with. The correct commands to install the Brackets snap package are:
Note that a snap in classic confinement behaves as a traditionally packaged application with full access to the system.
If Brackets fails to open again after installing Windows software on PlayOnLinux, run the following commands:
sudo apt update
sudo apt upgrade
sudo snap refresh
sudo snap revert brackets
sudo snap refresh brackets
setsid brackets
karel
  • 122,292
  • 133
  • 301
  • 332
Even after following the instructions given by @karel I was facing lots of bugs in Brackets. For example error in Live Preview and problems in installing extensions and themes.
I uninstalled Brackets snap package by
sudo snap remove brackets
sudo snap refresh
Then I installed Brackets via ppa by
sudo add-apt-repository ppa:webupd8team/brackets
sudo apt update
Now everything is working just fine. Also there is no longer any conflict with Playonlinux.
Sonevol
  • 696
