My Dell Ubuntu 18.04 machine warns me that downloading HPLIP-3.18.7. could damage it. Even after using a different download link to download it, it runs unsuccessfully. Consequently, the printer remains unresponsive.
fkraiem
  • 12,813
best delete an existing version of hplip; before adding a newer version;
delete thoroughly with sudo apt purge hplip
so even if you think you have already installed 3.18.7, do the above and reinstall as described below
to install 3.18.7 of hplip; go here https://developers.hp.com/hp-linux-imaging-and-printing/gethplip and click to download and SAVE what will be hplip-3.18.7.run
open a terminal; (hold down control and alt and t keys all at once); copy each command below and paste into the terminal; to paste into the terminal, click in the terminal window to make it live, then hold down three keys there: control and shift and v
cd Downloads
sh hplip-3.18.7.run
and that should install this version; check it is installed with dpkg -l hplip and it should say 3.18.7
pdc
  • 1,132
hplip 3.18.7 doesn't work on my Ubuntu 18.04.1 installation, but hplip 3.18.6 does.
My HP LaserJet M1132 Multifunction Printer is detected and configured properly with hplip 3.18.7, and hp-check shows no errors nor warnings, but a Cups test page stays in the queue with state "Filter failed". In /var/log/cups/error_log I see:
D [29/Aug/2018:17:42:31 -0300] [Job 13166] prnt/hpcups/HPCupsFilter.cpp 644: DEBUG: SHIVA inside the while loopprnt/hpcups/HPCupsFilter.cpp 648: DEBUG: imageProcessorStartPage failed result = 2
D [29/Aug/2018:17:42:31 -0300] [Job 13166] STATE: +connecting-to-device
D [29/Aug/2018:17:42:31 -0300] [Job 13166] STATE: -connecting-to-device
D [29/Aug/2018:17:42:31 -0300] [Job 13166] STATE: -media-empty-error,media-jam-error,hplip.plugin-error,cover-open-error,toner-empty-error,other
D [29/Aug/2018:17:42:31 -0300] [Job 13166] PAGE: 1 1\r
D [29/Aug/2018:17:42:31 -0300] [Job 13166] PID 3566 (/usr/lib/cups/filter/hpcups) crashed on signal 11.
See also https://bugs.launchpad.net/hplip/+bug/1788706
You can download hplip 3.18.6 from here, then install it as usual, with sh hplip-3.18.6.run
If you find any problem during installation, specially downloading your printer driver, run hp-plugin
As a final check, running hp-check should show no errors (and preferably no warnings as well). Test your setup, e.g., by printing a test job from Cups.
Ricardo
  • 168
