I have a laptop with 17.10, with all updates. It is using full disk encryption
I just did the update to 18.04 today. All went well, it asked me to reboot at the end, so did I.
Upon boot, I was prompted for the luks passphrase, no way to get it successful. The console tells me
No key available with this passphrase.
Thought it must have been an issue with kernel version. Tested with a previous kernel, didn't help.
I've tested as well with both 18.04 and 17.10 live usb sticks with no more luck:
cryptsetup luksOpen --test-passphrase /dev/sda5 --verbose --debug
# cryptsetup 1.7.3 processing "cryptsetup luksOpen --test-passphrase /dev/sda5 --verbose --debug"
# Running command open.
# Locking memory.
# Installing SIGINT/SIGTERM handler.
# Unblocking interruption on signal.
# Allocating crypt device /dev/sda5 context.
# Trying to open and read device /dev/sda5 with direct-io.
# Initialising device-mapper backend library.
# Trying to load LUKS1 crypt type from device /dev/sda5.
# Crypto backend (gcrypt 1.7.8) initialized in cryptsetup library version 1.7.3.
# Detected kernel Linux 4.13.0-21-generic x86_64.
# Reading LUKS header of size 1024 from device /dev/sda5
# Key length 64, device size 498616320 sectors, header size 4036 sectors.
# Timeout set to 0 miliseconds.
# Password retry count set to 3.
# Password verification disabled.
# Iteration time set to 2000 milliseconds.
# Checking volume  [keyslot -1] using [none] passphrase.
# Interactive passphrase entry requested.
Enter passphrase for /dev/sda5:
# Trying to open key slot 0 [ACTIVE_LAST].
# Reading key slot 0 area.
# Using userspace crypto wrapper to access keyslot area.
# Trying to open key slot 1 [INACTIVE].
# Trying to open key slot 2 [INACTIVE].
# Trying to open key slot 3 [INACTIVE].
# Trying to open key slot 4 [INACTIVE].
# Trying to open key slot 5 [INACTIVE].
# Trying to open key slot 6 [INACTIVE].
# Trying to open key slot 7 [INACTIVE].
Followed this thread https://www.saout.de/pipermail/dm-crypt/2012-September/002735.html to check my luks header is healthy. Didn't find anything suspicious.
Of course I'm confident on the password.
Any hint on how to proceed ?
rcomblen
  • 275
you should try the answer to this question : Ubuntu with full disk encryption - bad password after upgrade to 18.04
It worked for me.
