16
I've been using VNC for many years but I don't know why this happens sometimes. With a new Ubuntu 16.04 machine, I first tried using Vino. It worked well, but I decided it is rather slow, so I decided to use TightVNC with the Xfce4 window manger. However I get this "grey screen" (I have experienced it before couple of times..) again.
My xstartup is :
#!/bin/sh
xrdb $HOME/.Xresources xsetroot -solid grey startxfce4 &
and the log file is :
24/08/18 09:47:09 Xvnc version TightVNC-1.3.10
24/08/18 09:47:09 Copyright (C) 2000-2009 TightVNC Group
24/08/18 09:47:09 Copyright (C) 1999 AT&T Laboratories Cambridge
24/08/18 09:47:09 All Rights Reserved.
24/08/18 09:47:09 See http://www.tightvnc.com/ for information on TightVNC
24/08/18 09:47:09 Desktop name 'X' (kimchan:1)
24/08/18 09:47:09 Protocol versions supported: 3.3, 3.7, 3.8, 3.7t, 3.8t
24/08/18 09:47:09 Listening for VNC connections on TCP port 5901
Font directory '/usr/share/fonts/X11/75dpi/' not found - ignoring
Font directory '/usr/share/fonts/X11/100dpi/' not found - ignoring
/usr/bin/startxfce4: X server already running on display :1
Xlib:  extension "RANDR" missing on display ":1".
xfce4-session: Another session manager is already running
24/08/18 09:48:08 Got connection from client 129.254.132.39 24/08/18 09:48:08 Using protocol version 3.8 24/08/18 09:48:12 Full-control authentication passed by 129.254.132.39 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding 16 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding 22 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding 21 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding 15 24/08/18 09:48:12 Using zlib encoding for client 129.254.132.39 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding -314 24/08/18 09:48:12 Enabling full-color cursor updates for client 129.254.132.39 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding -223 24/08/18 09:48:12 Pixel format for client 129.254.132.39: 24/08/18 09:48:12 32 bpp, depth 24, little endian 24/08/18 09:48:12 true colour: max r 255 g 255 b 255, shift r 16 g 8 b 0 24/08/18 09:48:12 no translation needed 24/08/18 09:48:12 Using raw encoding for client 129.254.132.39 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding 22 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding 21 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding 16 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding 15 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding -314 24/08/18 09:48:12 Enabling full-color cursor updates for client 129.254.132.39 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding -223 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding 16 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding 22 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding 21 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding 15 24/08/18 09:48:12 Using zlib encoding for client 129.254.132.39 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding -314 24/08/18 09:48:12 Enabling full-color cursor updates for client 129.254.132.39 24/08/18 09:48:12 rfbProcessClientNormalMessage: ignoring unknown encoding -223
What is wrong here? Is X server already running on display :1 an error? And how about "RANDR" missing on display:1? And what are those many ignoring unknown encoding messages?
Chan Kim
  • 2,293
6 Answers6
28
I found https://bbs.archlinux.org/viewtopic.php?id=180965
and changed my xstartup to
#!/bin/sh
unset SESSION_MANAGER
unset DBUS_SESSION_BUS_ADDRESS
startxfce4 &
and it works!
Chan Kim
  • 2,293
Working config for Gnome
#!/bin/sh
# Config requires following packages:
# gnome-panel nautilus gnome-terminal metacity
export XKL_XMODMAP_DISABLE=1
unset SESSION_MANAGER unset DBUS_SESSION_BUS_ADDRESS
[ -x /etc/vnc/xstartup ] && exec /etc/vnc/xstartup [ -r $HOME/.Xresources ] && xrdb $HOME/.Xresources xsetroot -solid grey
gnome-session & gnome-panel &
metacity & gnome-terminal &
Following the other upvoted answer, I simply put:
#!/bin/sh
startxfce4 &
in my ~/.vnc/xstartup file and I was able to connect locally. Additionally, I had to edit /etc/vnc/conf adding the line:
$localhost = "no";
to let other machines on my private network connect to the tigervnc server (as opposed to only localhost clients).
None of the above worked for me. I found a suggestion on https://wiki.archlinux.org/index.php/TigerVNC#Recommended_security_settings
Try this:
vncserver -geometry ... -depth 24
Also make sure you have 'dbus-x11' installed
sudo apt-get install dbus-x11
According to packages.debian.org: This package contains the dbus-launch utility, which automatically launches one D-Bus session bus per X11 display per user. If the dbus-user-session package is also installed, it takes precedence over this package.
coder1
su -l username -c "(export DISPLAY=:5; dbus-launch --exit-with-session; vncserver -geometry 1792x899 -depth 24 :5)"
The command "dbus-launch --exit-with-session" sets dbus variables to be specific to the user running vncserver, otherwise it might pick them up from somewhere else or not have them set at all.
DBUS_SESSION_BUS_PID=31898 DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1003/bus
These need to be set correctly or you will get a blank screen or permission denied. For example DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1003/bus Where 1003 is the id of the user.
