gui@pcgui:~$ sudo apt-get install r-base
Reading package lists... Done
Building dependency tree
r-base : Depends: r-base-core (>= 3.5.1-1bionic) but it is not going to be installed
Depends: r-recommended (= 3.5.1-1bionic) but it is not going to be installed
Recommends: r-base-html but it is not going to be installed
I dont what to do.
and, I've found the solution which failed to help me, if i input
gui@pcgui:~/Downloads$ sudo apt install r-base-core
r-base-core : Depends: libblas3 but it is not installable or
libblas.so.3 but it is not installable
Depends: libcurl4 (>= 7.28.0) but it is not installable
Depends: liblapack3 but it is not installable or
liblapack.so.3 but it is not installable
Depends: libtcl8.6 (>= 8.6.0) but it is not installable
Depends: libtk8.6 (>= 8.6.0) but it is not installable
Recommends: r-recommended but it is not going to be installed
Recommends: r-base-dev but it is not going to be installed
Recommends: r-doc-html but it is not going to be installed
and, for last, i've encountered a situation which asked me [Y/n] and I input Y and it aborted.
