I'm currently running Ubuntu 18.04 on MSI GS65, running into what seems to be a persisting age old issue:
WIFI IS DISABLED BY HARDWARE SWITCH AFTER SUSPEND
only can comeback up after reboot.
sudo rfkill list all shows
0: hci0: Bluetooth
    Soft blocked: yes
    Hard blocked: no
1: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: yes
I've tried the following methods so far, and nothing has worked for me
  1. Hitting the fn+f10 (f10 has a airplane icon on it) doesn't work
  2. rfkill unblock all
  3. I only tried manually restart network manager service as described in this post. Did not implement the script since it didn't work manually Wifi doesn't work after suspend after 16.04 upgrade
  4. tried black listing the msi_wmi module as described in this post How to unblock something listed in rfkill?
  5. manually restart the driver as described in this post. I didn't try the script because it didn't work manually. And also because there isn't anymore folders after my /lib/systemd/system-sleep/ . I'm pretty new to ubuntu, so I wasn't sure what to do. (Yet another) Wifi issue after suspend in Ubuntu 16.04
Richard
  • 102
I downgraded to Ubuntu 16.04, however had the same problem. I found the solution. Essentially enabling the airplane mode key on my system.
credit to Gibbsoft Wifi Hard Blocked After Suspend in Ubuntu on GS65
  1. $sudo nano /etc/default/grub
  2. add to the bottom of the file and save
    GRUB_CMDLINE_LINUX_DEFAULT="acpi_osi=! acpi_osi='Windows 2009' quiet splash"
  3. $sudo update-grub
  4. reboot
now i press fn + f10 (airplane mode key) to enable wifi after suspend
Richard
  • 102
If anybody stumbles upon this and has a dual-boot Windows 10 GS65, these instructions may not work. These instructions are meant for GRUB, I setup my laptop to boot using EFI.
Try
sudo kernelstub -a "acpi_osi=! acpi_osi=\"Windows 2009\""
-1
I got an error from grub when I did this on Ubuntu 20.04, but escaped double-quotes worked.
GRUB_CMDLINE_LINUX_DEFAULT="acpi_osi=! acpi_osi=\"Windows 2009\" quiet splash"
Ray
