I have been trying to install Ubuntu 16.10 or 18.04 (would prefer 18.04 as it will end up having longer LTS). The issue has been the screen tearing that accompanies the Linux System after install. I have attached a video showing the display issues.
The tearing only starts once I've booted into Ubuntu; the OS selection menu is perfectly fine.
Specs:
Model: Lenovo Ideapad 720S 13IKB
CPU: Intel 8550U
RAM: 8GB
Display: 4K
I've tried adding the xorg config files, but that has led to nothing, unfortunately.
I've tried altering the default resolution and refresh rates as well, but same results.
I have updated the BIOS on my laptop using the Lenovo Update tools in Windows.
I'm at a loss, any ideas?
Satirez
  • 31
I had this same issue and following this guide made it work for me:
  • boot to the GRUB menu
  • select Ubuntu
  • hit the e key
  • use arrow keys to move
  • find the line that has "quiet splash"
  • add nomodeset, so "quiet splash nomodeset"
  • hit F10 to exit and continue boot
  • see if it flickers
If you want to make it permanent you can edit the grub file by opening a terminal and doing this:
  • sudo gedit /etc/default/grub
  • GRUB_CMDLINE_LINUX_DEFAULT=”quiet splash nomodeset" then exit the gedit
  • sudo update-grub
  • reboot
The original guide I read was here: Ubuntu randomly started blinking the screen on boot
Michael
