I have Windows 10 and I am trying to install ubuntu 18.04.1 with no success. Here is my system info:
  • HP Envy x360 Laptop with SSD (with GPT)
  • I have 100 MB EFI System parition (installed with Windows 10) Here is my Disk Partition table
  • Windows 10 is installed in UEFI mode
  • Windows 10 Fast Reboot is disabled
  • From BIOS Secure Boot is disabled
  • ubuntu 18.04.1 ISO copied to USB using Rufus 3.1 in GPT mode
  • On restart ubuntu USB loads fine as I clicked on 'Try ubuntu'
  • Once ubuntu is running then I click on Install ubuntu
  • And then I get this error:
The 'grub-efi-amd64-signed' package failed to install into / target/. Without the GRUB boot loader, the installed system will not boot.
I have tried many times by selecting/deselecting options like 'install 3rd party drivers', 'install updates during installation' but I always get the same error.
I have searched on web and many users are facing the same error and I have tried to apply some fixes / workarounds (like disabling Fast Reboot , disabling Secure Boot etc) but none worked in my case. I have even tried increasing the EFI partition size to 500 mb but I still got the same error.
Could someone please suggest a solution for this problem. I thought ubuntu is a friendly Linux distro and its installation will be as easy as installing Windows... but its giving me some pains....
I would really appreciate some help here.
EDIT:
Here is my Parted -l result
Thanks, Maverick
Dany
I would boot into the Ubuntu Live without installing and in terminal do one line at a time
sudo mkdir -p /mnt/boot/efi
sudo mount /dev/sda7 /mnt
sudo mount /dev/sda2 /mnt/boot/efi
for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; done
sudo chroot /mnt
apt-get update
apt-get install --reinstall grub-efi grub-efi-amd64 grub-efi-amd64-signed
os-prober
update-grub
exit
Then see if you can boot into the install
Jeremy31
  • 13,293
