Get:1 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 gnome-software-common all 3.28.1-0ubuntu4.18.04.1 [2,482 kB]
Err:1 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 gnome-software-common all 3.28.1-0ubuntu4.18.04.1
  Hash Sum mismatch
  Hashes of expected file:
   - SHA256:20e50c1116271b6c38526a5d78e78c51b86bc48c7c03d0005ebe06a3e3fb23de
   - SHA1:01c39d0c31ccafba417891022bd61e6c32ae72a3 [weak]
   - MD5Sum:4e0888a7d1cf9a766599c554287910c1 [weak]
   - Filesize:2481700 [weak]
  Hashes of received file:
   - SHA256:af6b6c41ed8389b2aa5f672ede2c845baa5aa1eaeacec9de6ac34fac3fa53416
   - SHA1:2a769e00e6d76749e0f2b3d54975efa7d6b60701 [weak]
   - MD5Sum:6bfd90cbe01b7c3e5f666860f5bd73b2 [weak]
  Last modification reported: Thu, 17 May 2018 11:30:45 +0000
Get:2 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 ubuntu-report amd64 1.2.0~bionic [1,694 kB]
Err:2 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 ubuntu-report amd64 1.2.0~bionic
  Hash Sum mismatch
   - SHA256:410b0572c1b66af9648c01bf66804c09986f00ed0843cf459a9d282c8d06402d
   - SHA1:e731d01aa7370cf5a8882949c04c081816792db9 [weak]
   - MD5Sum:153fa99051248ebfe7880ab9e04cc307 [weak]
   - Filesize:1693624 [weak]
   - SHA256:c7df99a8fdc7812a29ed79900c32fab6b371821f17e6463acbee9ac0f8684df5
   - SHA1:a57af71ecd4813d1a9190105d314248eac43f5b7 [weak]
   - MD5Sum:3fb8028c3be9b1411cf21ceefef78d0d [weak]
  Last modification reported: Tue, 03 Jul 2018 07:03:24 +0000
Fetched 4,175 kB in 6s (708 kB/s)
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/g/gnome-software/gnome-software-common_3.28.1-0ubuntu4.18.04.1_all.deb  Hash Sum mismatch
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-report/ubuntu-report_1.2.0~bionic_amd64.deb  Hash Sum mismatch
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I seem like your apt repository is not having some issue.
Please check sources.list using the following command sudo vim /etc/apt/sources.list
I this some url's were missed in that file.
Here I'm providing new sources.list file for ubuntu 18.04 LTS. Back up your old sources.list file and replace the contents in the in below link:
https://docs.google.com/document/d/1DXVUaqi96hMuhecEMSinFVdyFwZWozbLOFu_-ZL_o08/edit
Now do sudo apt-get update Hope this helps
If you're behind a proxy, do the following
sudo vi /etc/apt/apt.conf.d/proxy.conf
Define a http: and a https: proxy
Acquire::http::Proxy "http://user:password@proxy.server:port/";
Acquire::https::Proxy "https://user:password@proxy.server:port/";
Usually, there's no username when using a LAN-based proxy, so in that case you can just type the IP/hostname i.e
"http://192.168.1.10:3128/";
and same for the https counterpart
"https://192.168.1.10:3128/";
Run apt update to see if the error is gone.
Betro
  • 31
