I want to be able to scan from the terminal and then send the scanned output to a specific directory. Can this be done from the terminal.
scanimage is installed by default.
And here's me using it:
$ scanimage -L
device `epson2:libusb:002:003' is a Epson PID 084F flatbed scanner
$ scanimage -d "epson2:libusb:002:003" --format tiff > rawr.tiff
Obviously that generates a tiff-formatted file. Lossless but usually quite vast. You can convert this down withou an intermediary file by installing imagemagick and then piping the scan output into the convert command:
$ scanimage -d "epson2:libusb:002:003" --format=tiff | convert tiff:- scan.jpg
- 299,380
Tested in 18.04 LTS, works fine.
You may need to set a scan resolution (150/300/600 dpi). To do this use "--resolution" param (this param don't mentioned in scanimage manpage docs). It helps you to reduce the size of produced files.
Example for 600 dpi scan with png output:
scanimage "epson2:libusb:002:003" --resolution 600 --format=png
Output file size difference between 300 and 600 dpi is significant if you scan an image (not text).
My values for default A4 image:
- 300 dpi: 2560px * 3150px image, 2-20 Mb *.png file
- 600 dpi: 5120px * 7020px image, 30-65 Mb *.png file
Here's a simple command line tool I wrote for myself to scan documents, uses scanimage and imagemagic to scan:
https://github.com/pohape/command-line-scanner
To get a JPEG file with the scan result:
./scan.sh ./test.jpg
To get a PNG file with the scan result:
./scan.sh ./test.png
To get a PDF file with the scan result:
./scan.sh ./test.pdf
- 562
