I'm running LUbuntu 18.04 on a Lenovo T450s. The SD card is usually recognized just fine when it is inserted into the slot, but sometimes, inexplicably, I will insert a card and nothing will happen. I don't see any messages in dmesg, no error message, no indication of any kind that I did anything. If I reboot it seems to clear the problem up, especially if the card is already in the slot - although this is inconvenient because then I have to get everything back to where it was when I was ready to read files off the card.
I'm not 100% sure, but I have read that the SD card reader on this system is PCI based. Is there some command I can run to diagnose and possibly fix this issue when it occurs without the need for a reboot?
Michael
  • 1,195
Per the suggestion of @mbeyss I found the card reader under PCI (lspci) and it is reported as:
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5227 PCI Express Card Reader (rev 01)
In this answer I found some modprobe commands which purport to reload the drivers. But when I try to "modprobe -r" the rtsx_pci module, I get the error:
modprobe: FATAL: Module rtsx_pci is in use.
Funny, I thought modprobe was supposed to figure out dependencies for me automatically. I found this thread; lsmod reports these modules:
rtsx_pci_ms            20480  0
memstick               16384  1 rtsx_pci_ms
rtsx_pci_sdmmc         24576  0
rtsx_pci               65536  2 rtsx_pci_sdmmc,rtsx_pci_ms
So I ran the following commands:
sudo modprobe -r rtsx_pci_sdmmc rtsx_pci_ms memstick rtsx_pci
sudo modprobe rtsx_pci
Now, if I run this without an SD card in the slot, when I subsequently insert a card it is not recognized, no messages show up in dmesg, etc. Why the card is not subsequently recognized is an open question. But if the card is in the slot when I run this, the card is immediately recognized and I get the popup asking me what I want to do with the card.
Michael
  • 1,195
