Acidentally I deleted two directories of images from the internal stockage memory of my Asus zenfone MAX 3 and I don't have an SD card on it. I found foremost is a tool to recover deleted data. But it's not able to give it the /run/user/1000/gvfs/mtp:host=%5Busb%3A001%2C0 as a partition to scan it. I active the USB debug option following these instructions:
  1. Go to Settings -> About Phone/Tablet.
  2. Go to “Build Number” at the end of the Scroll list.
  3. Tap on “Build Number” repeatedly 3 times
  4. Now Developer Option will be included in setting list of yours now. Go to “Develop Options” to check USB debugging > OK. Done.
But in USB configuration I have:
  1. Load
  2. MTP(Media Transfer Protocol)
  3. PTP (Picture Transfer Protocol)
  4. RNDIS (USB Ethernet)
  5. Audio Source
  6. MIDI
I plug the usb cable to the pc and I got this alert message:
 Use USB to transfer files
I pressed OK.
Slim
  • 255
I don't know which mtp device you have but I have been able to recover files using photorec (part of the package testdisk) where scapel (outdated) and foremost (also outdated) were not able to. I also recommend setting the mtp device to mass storage so photorec can read it as mentioned here How to mount Smartphone to recover files
Luis Alvarado
  • 216,643
You basically can't - because MTP is a high level protocol. It doesn't give you access to the underlying file system; it gives you access to the filesystem as seen by the system hosting the MTP session (e.g. phone in this example). The systems sees the files as deleted, so it's not accessible over MTP.
You need to gain access to this device somehow. Some phones can show up as mass storage devices, and if it's a SD card you can pop this into your computer. Or you can find a recovery tool that runs at the phone.
vidarlo
  • 23,497
