I tried this using a terminal with the disk dump command. After everything was done the thumb drive appears to have everything there. But I'm trying to go from Ubuntu 14.4 32x to Ubuntu 18.4 64x and it is not booting. Can someone please help?
Asked
Active
Viewed 154 times
If you are already in Ubuntu, use "startup disk creator" to make your install media.
From activities window search "startup" and click startup disk creator.
From this window you simply click the "other" button and browse to your ISO. Then select your thumb drive in "Disk to Use" and click make startup disk.
Using dd doesn't work for some reason.
There is a great tutorial here:
Joshua Besneatte
- 4,861
