upgraded to Ubuntu 18.04 LTS from 16.04 LTS today. But on login screen only option for Kodi is available on the gear icon.
a). Appreciate Any suggestions/steps available to install desktop on it. b). Is all data from old unity desktop lost (chrome bookmarks/files) ? i feel i made a mistake to upgrade ubuntu.
login screen shot
First I would try to run all of your upgrades:
sudo apt update && sudo apt upgrade
Then make sure you have gdm3 installed:
sudo apt install gdm3
Then reboot and you should be good to go.
Joshua :
thanks!
followed steps to get the updates: a). How do I access console from GDM ? (wayland) ~ but getting file system is read-only mode
next tried b). What to do after Failed to start Load Kernel Modules executed commands ~ apt-get update; dpkg --configure -a; apt-get dist-upgrade; apt-get -f install;
but i feel the ethernet port is not working hence not getting the updates. Will try the above steps on a loaner PC with working ethernet port & report back.
moved HDD to another loaner laptop & tried to run the updates command but still unable to get the updates. I am unable to resolve error "Failed to start Load Kernel Modules" . Somehow got the file system to be read/write mode but still stuck with Kodi.
Will try out something else otherwise I will go back to 16.04 on a new hdd & try to recover data from drive.
https://ubuntuforums.org/showthread.php?t=2326216 https://stackoverflow.com/questions/51884940/failed-to-start-load-kernel-modules-on-ubuntu https://ubuntuforums.org/showthread.php?t=2318779&p=13466943#post13466943
I am giving up on this & going back to 16.04. Above suggestions did not work for me.
