This issue appeared after upgrading from Ubuntu 16.04 to 18.04.
I have an Intel NUC6i3SYH installed as a headless server on my local network. It has no display and no keyboard attached to it. I control it from my desktop computer, using Remmina. This worked fine when Ubuntu 16.04 was installed on the NUC.
I have now upgraded the NUC to Ubuntu 18.04.01. Suddenly Remmina does not work as intended any more: it can connect to the NUC and asks for the password to get access. But then it only shows a black screen. Remmina only works if I connect a display to the NUC at the time of booting. As long as the NUC senses a display does it provides graphics to Remmina. The graphics in Remmina freeze when removing the display. What do I need to do to have graphics visible in Remmina without having a display connected to the NUC?
Some technical specs about the NUC: NUC6i3SYH, CPU: i3-6100U (formerly called Skylake), using integrated graphics Intel HD Graphics 520.
Jan
  • 199
I have found a solution which works for the issue I described above. This answer comes from a reply by user Stefan Lemmens (https://askubuntu.com/users/421108/stefan-lemmens) at question: How to use Ubuntu 18.04 on VNC without display attached? His answer involves three steps:
(1) create a 20-intel.conf file, which creates a virtual display.
(2) create a shell script, setting the virtual display and connecting it.
(3) add the shell script to the Startup Applications, thus having it executed upon each reboot of the machine.
I made one change compared to his overview: I wanted a different resolution for the virtual display, so I used different xrandr parameter values. I found a description on how to find the correct parameter values here: https://ubuntuforums.org/showthread.php?p=8595940
Update April 2021: after upgrading to Ubuntu 20.04 LTS I had more graphic issues with this headless server. I asked a question about these issues: Intel Graphics issue after upgrade to Ubuntu 20.04.1 In the end I solved it by buying an HDMI plug. This makes the NUC think that a monitor is attached at boot time. Then I didn't need the software tricks to get things working. I removed the software steps as described above.
Jan
  • 199
I have a easy fix which I stumbled upon. If you have one of those VGA to HDMI or VGA to Display port adapters lying around, you can use it to get past this Monitor or display issue. I used a cheap one $7 adapter and it worked for me. My Ubuntu server is a Lenovo Thinkserver. Hope that helps someone. Especially useful if you are trying to use VNC.
