I am trying to assign a series of static IP addresses to my homelab server so that I can run a media service.
I edited /etc/netplan/ with the following:
01-netcfg.yaml:
network:
version: 2
renderer: networkd
ethernets:
    enp0s20f0:
        dhcp4: no
        addresses: [192.168.0.100/24]
        gateway4: 192.168.0.1
        nameservers:
            addresses: [192.168.0.1,8.8.4.8,8.8.8.8]
Then I repeated for the other three ports I was assigning. e.g., 02-netcfg.yaml, etc.
When I run
sudo netplan apply
I get the correct IP addresses.
After a period of mins, I lose the assigned numbers and get new IPs from my router's DHCP.
I've also tried to set the static IPs via the router, but I get the same problem.
Any ideas?
(I'm happy to provide more logs as needed.)
UPDATE: Output from syslog
/var/log$ tail -100 syslog
Aug 19 12:13:06 mythtv-server systemd[1]: Starting Network Name Resolution...
Aug 19 12:13:06 mythtv-server systemd-resolved[14306]: Positive Trust Anchors:
Aug 19 12:13:06 mythtv-server systemd-resolved[14306]: . IN DS 19036 8 2 49aac11d7b6f6446702e54a1607371607a1a41855200fd2ce1cdde32f24e8fb5
Aug 19 12:13:06 mythtv-server systemd-resolved[14306]: . IN DS 20326 8 2 e06d44b80b8f1d39a95c0b0d7c65d08458e880409bbc683457104237c7f8ec8d
Aug 19 12:13:06 mythtv-server systemd-resolved[14306]: Negative trust anchors: 10.in-addr.arpa 16.172.in-addr.arpa 17.172.in-addr.arpa 18.172.in-addr.arpa 19.172.in-addr.arpa 20.172.in-addr.arpa 21.172.in-addr.arpa 22.172.in-addr.arpa 23.172.in-addr.arpa 24.172.in-addr.arpa 25.172.in-addr.arpa 26.172.in-addr.arpa 27.172.in-addr.arpa 28.172.in-addr.arpa 29.172.in-addr.arpa 30.172.in-addr.arpa 31.172.in-addr.arpa 168.192.in-addr.arpa d.f.ip6.arpa corp home internal intranet lan local private test
Aug 19 12:13:06 mythtv-server systemd-resolved[14306]: Using system hostname 'mythtv-server'.
Aug 19 12:13:06 mythtv-server systemd[1]: Started Network Name Resolution.
Aug 19 12:13:10 mythtv-server dhclient[11809]: DHCPDISCOVER on enp0s20f3 to 255.255.255.255 port 67 interval 11 (xid=0x80e80479)
Aug 19 12:13:10 mythtv-server dhclient[11809]: send_packet: No such device or address
Aug 19 12:13:10 mythtv-server dhclient[11809]: dhclient.c:2438: Failed to send 300 byte long packet over enp0s20f3 interface.
Aug 19 12:13:10 mythtv-server dhclient[28319]: DHCPDISCOVER on enp0s20f3 to 255.255.255.255 port 67 interval 20 (xid=0x6ab1ec09)
Aug 19 12:13:10 mythtv-server dhclient[28319]: send_packet: No such device or address
Aug 19 12:13:10 mythtv-server dhclient[28319]: dhclient.c:2438: Failed to send 300 byte long packet over enp0s20f3 interface.
Aug 19 12:13:11 mythtv-server dhclient[27706]: DHCPDISCOVER on enp0s20f3 to 255.255.255.255 port 67 interval 12 (xid=0x9f278b66)
Aug 19 12:13:11 mythtv-server dhclient[27706]: send_packet: No such device or address
Aug 19 12:13:11 mythtv-server dhclient[27706]: dhclient.c:2438: Failed to send 300 byte long packet over enp0s20f3 interface.
Aug 19 12:13:15 mythtv-server dhclient[28739]: DHCPDISCOVER on enp0s20f1 to 255.255.255.255 port 67 interval 3 (xid=0xf969ca13)
Aug 19 12:13:15 mythtv-server dhclient[28739]: send_packet: No such device or address
Aug 19 12:13:15 mythtv-server dhclient[28739]: dhclient.c:2438: Failed to send 300 byte long packet over enp0s20f1 interface.
Aug 19 12:13:18 mythtv-server dhclient[11809]: DHCPDISCOVER on enp0s20f1 to 255.255.255.255 port 67 interval 7 (xid=0x8354462)
Aug 19 12:13:18 mythtv-server dhclient[11809]: send_packet: No such device or address
Aug 19 12:13:18 mythtv-server dhclient[11809]: dhclient.c:2438: Failed to send 300 byte long packet over enp0s20f1 interface.
Aug 19 12:13:18 mythtv-server dhclient[3290]: DHCPDISCOVER on enp0s20f3 to 255.255.255.255 port 67 interval 9 (xid=0xc9123118)
Aug 19 12:13:18 mythtv-server dhclient[3290]: send_packet: No such device or address
Aug 19 12:13:18 mythtv-server dhclient[3290]: dhclient.c:2438: Failed to send 300 byte long packet over enp0s20f3 interface.
Aug 19 12:13:18 mythtv-server dhclient[28739]: DHCPDISCOVER on enp0s20f1 to 255.255.255.255 port 67 interval 6 (xid=0xf969ca13)
Aug 19 12:13:18 mythtv-server dhclient[28739]: send_packet: No such device or address
Aug 19 12:13:18 mythtv-server dhclient[28739]: dhclient.c:2438: Failed to send 300 byte long packet over enp0s20f1 interface.
Aug 19 12:13:21 mythtv-server dhclient[11809]: DHCPDISCOVER on enp0s20f3 to 255.255.255.255 port 67 interval 15 (xid=0x80e80479)
UPDATE2: I've added the output from ip a
ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
   link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
   inet 127.0.0.1/8 scope host lo
      valid_lft forever preferred_lft forever
   inet6 ::1/128 scope host
2: enp0s20f0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
   link/ether ac:1f:6b:46:da:74 brd ff:ff:ff:ff:ff:ff
   inet 192.168.0.100/24 brd 192.168.0.255 scope global enp0s20f0
   inet 192.168.0.6/24 brd 192.168.0.255 scope global secondary dynamic      enp0s20f0
      valid_lft 2391sec preferred_lft 2391sec
   inet6 2605:a000:45c9:3100::3/128 scope global dynamic noprefixroute
      valid_lft 3277sec preferred_lft 1477sec
   inet6 2605:a000:45c9:3100:ae1f:6bff:fe46:da74/64 scope global dynamic mngtmpaddr noprefixroute
      valid_lft 604796sec preferred_lft 604796sec
   inet6 fe80::ae1f:6bff:fe46:da74/64 scope link
3: enp0s20f1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
   link/ether ac:1f:6b:46:da:75 brd ff:ff:ff:ff:ff:ff
4: enp0s20f2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
   link/ether ac:1f:6b:46:da:76 brd ff:ff:ff:ff:ff:ff
   inet 192.168.0.102/24 brd 192.168.0.255 scope global enp0s20f2
   inet 192.168.0.68/24 brd 192.168.0.255 scope global secondary dynamic enp0s20f2
      valid_lft 2389sec preferred_lft 2389sec
   inet6 2605:a000:45c9:3100::2/128 scope global dynamic noprefixroute
      valid_lft 3379sec preferred_lft 1579sec
   inet6 2605:a000:45c9:3100:ae1f:6bff:fe46:da76/64 scope global dynamic mngtmpaddr noprefixroute
   inet6 fe80::ae1f:6bff:fe46:da76/64 scope link
5: enp0s20f3: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
   link/ether ac:1f:6b:46:da:77 brd ff:ff:ff:ff:ff:ff
Saxtheowl
  • 2,394
  • 22
crum
  • 29
It could be NetworkManager service that does that. Just purge it, and hopefully it will work.
For more details on how to purge it, goto : How do I disable network manager permanently?
NB :
  • (Source : netplan vs NetworkManager on Ubuntu 18.04 and above)
    NetworkManager is normally used in desktop applications, and was used in all prior versions of Ubuntu.
  • If you are using netplan, it's totally safe to remove NetworkManager
  • Fixed the same issue for me on Ubuntu 18.04.3 LTS.
pymym213
  • 521
-1
Check out this related bug on netplan...
https://bugs.launchpad.net/netplan/+bug/1781652
You can easily migrate back to ifupdown if you still have issues with netplan. I sure did.
