15
Looks like my Ubuntu 18.04 keeps one old Linux kernel under /boot (so I have 1 old and 1 current kernel). Is it possible to increase the number of old kernels to keep when running sudo apt autoremove or full-upgrade, e.g. I would like to keep the last three old kernels (hence I would have 3 old + 1 current = 4 kernels)? Rounding up disk space to 64MB for kernel and initrd.img x 4 = 256MB under /boot which I have plenty of room to spare and would like to keep some older kernels around just to be safe.
This can be done under CentOS 6 and 7 by editing /etc/yum.conf and setting installonly_limit=3 (it defaults to 5).
Ravexina
  • 57,256
Neon
  • 259
Sadly there is no such a configuration, and we should edit the script responsible of creating: /etc/apt/apt.conf.d/01autoremove-kernels.
So I looked into the script a little bit and some minor changes was enough to get what you want.
First create a backup of: /etc/kernel/postinst.d/apt-auto-removal:
sudo cp /etc/kernel/postinst.d/apt-auto-removal{,.bk}
Then find this line:
previous_version="$(echo "$debverlist" | sed -n 2p)"
and change it to:
previous_version="$(echo "$debverlist" | sed -n 2,4p)"
  • Now it should keep 3 old kernel + Running + Newly installed one
  • Of course you have to run it once manually or install a new kernel to make it take effect.
Or change the file with my modification so you can easily change the number of kernels you want to keep at:
NKER=1
#!/bin/sh
set -e
# Mark as not-for-autoremoval those kernel packages that are:
#  - the currently booted version
#  - the kernel version we've been called for
#  - the latest kernel version (as determined by debian version number)
#  - the second-latest kernel version
# In the common case this results in two kernels saved (booted into the
# second-latest kernel, we install the latest kernel in an upgrade), but
# can save up to four. Kernel refers here to a distinct release, which can
# potentially be installed in multiple flavours counting as one kernel.
# Specify the number of kernels you want to keep
NKER=1
NKER=$((NKER+1))
eval $(apt-config shell APT_CONF_D Dir::Etc::parts/d)
test -n "${APT_CONF_D}" || APT_CONF_D="/etc/apt/apt.conf.d"
config_file="${APT_CONF_D}/01autoremove-kernels"
eval $(apt-config shell DPKG Dir::bin::dpkg/f)
test -n "$DPKG" || DPKG="/usr/bin/dpkg"
list="$("${DPKG}" -l | awk '/^[ih][^nc][ ]+(linux|kfreebsd|gnumach)-image-[0-9]+\./ && $2 !~ /-dbg(:.*)?$/ && $2 !~ /-dbgsym(:.*)?$/ { print $2,$3; }' \
   | sed -e 's#^\(linux\|kfreebsd\|gnumach\)-image-##' -e 's#:[^:]\+ # #')"
debverlist="$(echo "$list" | cut -d' ' -f 2 | sort --unique --reverse --version-sort)"
if [ -n "$1" ]; then
    installed_version="$(echo "$list" | awk "\$1 == \"$1\" { print \$2;exit; }")"
fi
unamer="$(uname -r | tr '[A-Z]' '[a-z]')"
if [ -n "$unamer" ]; then
    running_version="$(echo "$list" | awk "\$1 == \"$unamer\" { print \$2;exit; }")"
fi
# ignore the currently running version if attempting a reproducible build
if [ -n "${SOURCE_DATE_EPOCH}" ]; then
    unamer=""
    running_version=""
fi
latest_version="$(echo "$debverlist" | sed -n 1p)"
previous_version="$(echo "$debverlist" | sed -n 2,${NKER}p)"
debkernels="$(echo "$latest_version
$installed_version
$running_version
$previous_version" | sort -u | sed -e '/^$/ d')"
kernels="$( (echo "$1
$unamer"; for deb in $debkernels; do echo "$list" | awk "\$2 == \"$deb\" { print \$1; }"; done; ) \
   | sed -e 's#\([\.\+]\)#\\\1#g' -e '/^$/ d' | sort -u)"
generateconfig() {
    cat <<EOF
// DO NOT EDIT! File autogenerated by $0
APT::NeverAutoRemove
EOF
    for package in $(apt-config dump --no-empty --format '%v%n' 'APT::VersionedKernelPackages'); do
        for kernel in $kernels; do
            echo "   \"^${package}-${kernel}$\";"
        done
    done
    echo '};'
    if [ "${APT_AUTO_REMOVAL_KERNELS_DEBUG:-true}" = 'true' ]; then
        cat <<EOF
/* Debug information:
# dpkg list:
$(dpkg -l | grep '\(linux\|kfreebsd\|gnumach\)-image-')
# list of installed kernel packages:
$list
# list of different kernel versions:
$debverlist
# Installing kernel: $installed_version ($1)
# Running kernel: ${running_version:-ignored} (${unamer:-ignored})
# Last kernel: $latest_version
# Previous kernel: $previous_version
# Kernel versions list to keep:
$debkernels
# Kernel packages (version part) to protect:
$kernels
EOF
    fi
generateconfig "$@" > "${config_file}.dpkg-new"
mv -f "${config_file}.dpkg-new" "$config_file"
chmod 444 "$config_file"
Ravexina
  • 57,256
