I have a Brother printer HL-L2321D. I tried installing driver installer tool from here.
Earlier, these drivers were not giving two-sided print option. Now, with new Ubuntu install, these drivers are not able to print at all.
Here's my log:
You are going to install following packages.
   hll2320dlpr-3.2.0-1.i386.deb
   hll2320dcupswrapper-3.2.0-1.i386.deb
OK? [y/N] ->y
*EDIT: EULA Omitted*
wget -T 10 -nd --no-cache http://www.brother.com/pub/bsc/linux/packages/hll2320dlpr-3.2.0-1.i386.deb
--2018-08-17 10:55:39--  http://www.brother.com/pub/bsc/linux/packages/hll2320dlpr-3.2.0-1.i386.deb
Resolving www.brother.com (www.brother.com)... 23.32.28.26, 23.32.28.200
Connecting to www.brother.com (www.brother.com)|23.32.28.26|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 35574 (35K) [text/plain]
Saving to: ‘hll2320dlpr-3.2.0-1.i386.deb’
hll2320dlpr-3.2.0-1 100%[===================>]  34.74K  --.-KB/s    in 0.006s
2018-08-17 10:55:40 (5.95 MB/s) - ‘hll2320dlpr-3.2.0-1.i386.deb’ saved [35574/35574]
Do you agree? [Y/n] ->Y
wget -T 10 -nd --no-cache http://www.brother.com/pub/bsc/linux/packages/hll2320dcupswrapper-3.2.0-1.i386.deb
--2018-08-17 10:55:45--  http://www.brother.com/pub/bsc/linux/packages/hll2320dcupswrapper-3.2.0-1.i386.deb
Resolving www.brother.com (www.brother.com)... 23.32.28.200, 23.32.28.26
Connecting to www.brother.com (www.brother.com)|23.32.28.200|:80... connected.
Length: 18982 (19K) [text/plain]
Saving to: ‘hll2320dcupswrapper-3.2.0-1.i386.deb’
hll2320dcupswrapper 100%[===================>]  18.54K  --.-KB/s    in 0.001s
2018-08-17 10:55:46 (13.9 MB/s) - ‘hll2320dcupswrapper-3.2.0-1.i386.deb’ saved [18982/18982]
Hit:1 http://in.archive.ubuntu.com/ubuntu xenial InRelease
Hit:2 http://ppa.launchpad.net/clipgrab-team/ppa/ubuntu xenial InRelease
Hit:3 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu xenial InRelease
Hit:4 https://packages.microsoft.com/repos/vscode stable InRelease
Hit:5 http://ppa.launchpad.net/morphis/anbox-support/ubuntu xenial InRelease
Hit:6 http://ppa.launchpad.net/umang/indicator-stickynotes/ubuntu xenial InRelease
Reading package lists... Done
Building dependency tree
Package ia32-libs is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  lib32ncurses5 lib32z1
E: Package 'ia32-libs' has no installation candidate
 lib32stdc++6 : Depends: gcc-5-base (= 5.3.1-14ubuntu2) but 5.4.0-6ubuntu1~16.04.9 is to be installed
                Depends: lib32gcc1 (>= 1:4.2) but it is not going to be installed
                Depends: libc6-i386 (>= 2.18) but it is not going to be installed
dpkg -x hll2320dlpr-3.2.0-1.i386.deb /
dpkg -x hll2320dcupswrapper-3.2.0-1.i386.deb /
dpkg-deb: building package 'hll2320dlpr' in 'hll2320dlpr-3.2.0-1a.i386.deb'.
dpkg -b ./brother_driver_packdir hll2320dlpr-3.2.0-1a.i386.deb
dpkg-deb: building package 'hll2320dcupswrapper' in 'hll2320dcupswrapper-3.2.0-1a.i386.deb'.
dpkg -b ./brother_driver_packdir hll2320dcupswrapper-3.2.0-1a.i386.deb
dpkg -i --force-all hll2320dlpr-3.2.0-1a.i386.deb
Selecting previously unselected package hll2320dlpr:i386.
(Reading database ... 187592 files and directories currently installed.)
Preparing to unpack hll2320dlpr-3.2.0-1a.i386.deb ...
Unpacking hll2320dlpr:i386 (3.2.0-1) ...
Setting up hll2320dlpr:i386 (3.2.0-1) ...
/var/lib/dpkg/info/hll2320dlpr.postinst: 3: /var/lib/dpkg/info/hll2320dlpr.postinst: /opt/brother/Printers/HLL2320D/inf/braddprinter: not found
dpkg -i --force-all hll2320dcupswrapper-3.2.0-1a.i386.deb
Selecting previously unselected package hll2320dcupswrapper:i386.
(Reading database ... 187605 files and directories currently installed.)
Preparing to unpack hll2320dcupswrapper-3.2.0-1a.i386.deb ...
Unpacking hll2320dcupswrapper:i386 (3.2.0-1) ...
Setting up hll2320dcupswrapper:i386 (3.2.0-1) ...
lpinfo: cups-deviced failed to execute.
lpadmin -p HLL2320D -E -v usb://dev/usb/lp0 -P /usr/share/cups/model/brother-HLL2320D-cups-en.ppd
lpadmin: Bad device-uri scheme "usb".
###############################ls: cannot access '/usr/share/ppd/*.ppd': No such file or directory
0 (I): Specify IP address.
1 (A): Auto. (usb://dev/usblp0)
select the number of destination Device URI. ->1
lpadmin -p HLL2320D -v usb://dev/usblp0 -E -P /usr/share/cups/model/brother-HLL2320D-cups-en.ppd
Test Print? [y/N] ->y
wait 5s.
echo HLL2320D \| lpr  -P HLL2320D
hiigaran
  • 6,843
